Fender Flares
Old Apr 18, 2014 | 04:57 PM
TheBigDog's Avatar
TheBigDog
Default Fender Flares
If I go to rear fender flares will the C6 Z06 wheels fit under the flares? I can purchase a set of C6Z wheels and tires reasonable. I believe the tires are 325...not sure but they are plenty WIDE. Also I think they are 18" 19" front and rears.
Thanks,
The Big Dog
Old Apr 28, 2014 | 09:01 AM
TXGS507's Avatar
TXGS507
Mine are off of a C6Z.... 345's out back...
Old Apr 28, 2014 | 11:15 AM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Thanks,
The Big Dog
I have no experience with C6/C6Z offsets. I don't even know if the offsets vary by model... I do know of some members that have C6Z wheels in the rear and run a spacer to bring them further out and fill the well of flared quarters a little better. The fronts are a different story though as they will stick out past the fender. If you run flared fenders up front though it might not be so noticeable.
Old Apr 28, 2014 | 11:46 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I have mounted a set of C6 Grand Sport wheels (18x9.5 front and 19x12 rear) that have the same widths and offsets as the C6 Z06 wheels. Used a 1” hub centric wheel adapter in the rear. Thought I would have to trim 3/8” off the factory studs, but the Grand Sport wheels have enough of a pocket that it was not required. Have not installed the rear flared quarter panels from Corvette Creationz yet but the 325x30x19 rears should come out to flush with the flared fender in the rear when the flares are installed. The rears will also have the C6 Z06 mud flaps installed as well. The fronts were mounted without any spacers/adapters and while I am installing front flared fenders from L5, they stick out about ½” not very much at all but will look better with the front flares installed which have about 3/4" flare. Picture shows wheels and tires mounted with stock fenders front and rear.
Old Apr 28, 2014 | 12:41 PM
RW Foster's Avatar
RW Foster
What wheels are those?
To Fender Flares
