Timing chain change?
Old Apr 19, 2014 | 02:52 PM
rotorboys's Avatar
rotorboys
6th Gear
Default Timing chain change?
My 02 has 286,000 miles and the little things continue to break. My A/C Compressor went bad and I need to change it. I want to change the water pump, belts and tensioners while I am at it, does the timing chain need replacement at any time or mileage point? Anything else I should consider while I am working up front?
Old Apr 19, 2014 | 03:16 PM
JR-01's Avatar
JR-01
286K? Time to trade it in. They don't last forever.
Old Apr 19, 2014 | 03:59 PM
Adrians99FRC's Avatar
Adrians99FRC
If I were you I'd almost consider just pulling the motor and doing a rebuild instead of just doing a timing chain and little things here and there .. just have a completly fresh motor instead of having to worry about going back in to replace stuff
heck just to get to the timing chain your not far from pulling the motor
To Timing chain change?
