Shorted ac switch
Old Apr 19, 2014 | 10:16 PM
Steveb98vette's Avatar
Steveb98vette
6th Gear
Default Shorted ac switch
On 98 vette I was trying to get ac clutch to engage and when I jumped the pressure switch I lost fuel guage,oil sending unit and now my fans run continously. Any ideas on what happened and how to correct.
Old Apr 19, 2014 | 10:20 PM
Steveb98vette
6th Gear
Also I ran the codes with scanner it had 4 codes
1120
0113
1220
1516
Old Apr 20, 2014 | 09:15 AM
dadaroo's Avatar
dadaroo
1120
0113
1220
1516
Throw your scanner in the sock draw. Please pull your DIC codes. In the interim I will look at the circuit you jumpered.
What color wires did you jumper together. There are 3 there. Red/Black, Grey, and Black.
Old Apr 20, 2014 | 09:28 AM
Steveb98vette
6th Gear
Jumped red and grey fans came on then the thread I read said to jump from battery to black to engage clutch been trying to find wiring diagrahms so far not found one seems all codes say open circuit on ground
Old Apr 20, 2014 | 09:53 AM
dadaroo's Avatar
dadaroo
Here is the schematic. It would seem you put 12 volts or more into the low reference circuit. That would seem to be a bad thing for the PCM.
Please post the link to where you got this info.
PS: Was the pressure sensor disconnected when you did this?
Old Apr 20, 2014 | 11:16 AM
Steveb98vette
6th Gear
Yes it was disconnected
Old Apr 20, 2014 | 05:46 PM
dadaroo's Avatar
dadaroo
Link who said to do that?
To Shorted ac switch
