- How the Poor or Cheap Man Can Reset His TPMS
Step by step instructions for do-it-yourselfers
Browse all: Tires and Wheels
Titan TPMS sensors
After I bought them, I read some bad reviews (and some good reviews) on them, and was prepared to "chalk it up" to a learning experience.
On my first attempt I used a regular magnet. No joy AT ALL! Crap!
A few days later I borrowed a "super" magnet from a friend at work. Man, this thing was so strong that it was comical...I mean, this thing would stick to something, and you'd darn near have to get a pair of vise grips to get it off!
Well, I placed the magnet on the barrel of the rim, behind the valve stem, and the damned thing sucked itself up onto the rotor! ****! I had to wedge my big-assed meat hook in there and pry that little bastard off....note to self.....better control of the magnet.....
When I had the car in learning mode, I put the magnet right on top of the valve stem, and right away I got the "honk!" (I'm not sure, but the car might have been yelping in pain from the magnet!
)Did all four wheels in about 30 seconds. When I got in the car, only one wheel was showing a pressure indication....luckily I remembered that someone had posted that you might need to get up to about 20 mph in order to get the TPMS out of sleep mode; what do you know, as soon as I started driving, one by one, they all came to life!
I had really good luck with the Titan TPMS. I don't know about yours, but I suggest that before you throw in the towel, you try a big, rare-earth magnet....
IHTH,
KoreaJon
Please call me I will get you taken care of 941-921-0065 EXT 320
I appreciate the response. I really do. The sensors are working fine now. No issues. My biggest gripe was the difficulty I had getting them to be recognized by my vehicle. I realize everyone's skill level and mechanical experiance is different, but I really have done this more than a few times. I did follow the vendors instructions closely with no luck at all. As mentioned in an earlier reply, I also had to use a very strong magnet to trigger these. Might have been the make up of the wheel that I was using that caused the other magnets to be in affective. I realised that more than likely I was doing something wrong if none of the sensors were triggering. I dont expect every aftermarket part to work perfectly for every application. Thats just life and its what helps you to think outside the box. Im an engineer by trade and problems like this, "while frustrating" can be fun and very good learning experiences. Im not looking for a free ride or anything of the sort. I do appreciate your response, but they're working fine now. No harm, no foul and I'm not going to remove them just because the inflate/ deflate procedure didn't work or because for an unknown reason a "stronger" magnet needed to be used. Again, thank you. If they fail in the next few months I'll definitely contact you. Otherwise, no worries. Thats just the way it is sometimes.
Thanks,
David
Thanks,
David
