Convertible wind noise
Old Apr 30, 2014 | 09:56 AM
RowdyDakota's Avatar
RowdyDakota
Default Convertible wind noise
Is there adjustments on the windows to reduce wind noise?
Old Apr 30, 2014 | 02:48 PM
DanSavage's Avatar
DanSavage
Yes. And, top adjustments, too.
http://forums.corvetteforum.com/c5-g...with-pics.html (scroll to the bottom for pics)
http://forums.corvetteforum.com/c5-t...-and-tips.html
Old Apr 30, 2014 | 04:18 PM
RowdyDakota
Thanks Dan for the reply, I will give that a try when the weather here in SD changes
Old Apr 30, 2014 | 09:50 PM
Blueleader's Avatar
Blueleader
Default Me too!
Just what I needed and didn't know it. Thanks for the tips.....
Old May 1, 2014 | 09:49 AM
joe's98's Avatar
joe's98
St. Jude Donor '15, '17
I am taking mine in tomorrow to have those issues addressed. Looked at doing it myself, not enough confidence!
Old May 1, 2014 | 10:10 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Great information and links! So far, my fix has been to turn up my stereo.
Old May 1, 2014 | 11:11 AM
DanSavage's Avatar
DanSavage
You're welcome.
I had a minor leak on the passenger side at the top of the window. When it rained really hard, I discovered a small puddle on my passenger seat. Driver's side was dry.
Looking closely, I saw there was a difference between how each window fit to the top.
So, I adjusted the top and then the passenger side developed a whistle at speeds above 50mph.
I adjust the height and tilt-in of the passenger side and still didn't help.
Finally, I fine-tuned the star-adjustment on the top and now the passenger side is perfect. Almost no wind-noise at all. In comparison, the driver's side has quite a bit of wind noise.
Looked closely again at the driver's side and the back of the window is adjusted too high and is causing it to not seat properly on the B pillar seal.
Now that I know how quiet it can be when adjusted properly, Saturday's assignment is to lower the back of the driver's side window to get rid of the wind noise.
Old May 1, 2014 | 11:21 AM
DanSavage's Avatar
DanSavage
My fix up until I did my adjustments was to drive around with the top down.
Old May 1, 2014 | 11:24 AM
DanSavage's Avatar
DanSavage
YVW.
When I first got mine, I just accepted the wind noise as normal.
Now that the passenger's side is adjusted properly and is quiet, I know that excessive wind noise is abnormal.
To Convertible wind noise
