Melted 02 sensor...thoughts?
Old Apr 30, 2014 | 08:22 PM
DarkZ06's Avatar
DarkZ06
Default Melted 02 sensor...thoughts?
Put my LT's on with 02 extensions and new 02s. Was at car wash and it wouldn't start on first try, then sputtered a little on second start, jacked it up when I got home and found I did not secure the plug that connects to the 02 sensor and extensions, it was laying on header and half way melted. I got it secured and drove it the next day and it ran like a champ, no problems starting and no Codes or CEL. I really don't want to replace the 02 again if it's not necessary. If it was not working properly would I get a code?
Old Apr 30, 2014 | 11:25 PM
DarkZ06's Avatar
DarkZ06
Originally Posted by 8VETTE7
There are certainly a number of O2 related codes that can occur. If you have any active codes I would expect the CEL light to be illuminated. You can always Pull the codes and see if any are stored. Pull them with the engine running to see if they are Current or History. With engine OFF there could be History codes from when the problem you described occurred.
Thanks for the reply, no codes with car off, have not tried with it running but never had CEL. Wires to connector look fine just the housing is partially melted.
