Vararam VR-B2?
Old Apr 30, 2014 | 09:30 PM
Mylek's Avatar
Mylek
Default Vararam VR-B2?
Is anyone currently using a vararam VR -B2 CAI?
If so, what advantages have you noticed? Is there an increase in fuel mileage?
Old Apr 30, 2014 | 09:34 PM
WICKEDFRC's Avatar
WICKEDFRC
I had it on my 2000 FRC.
At first, I thought it was an awesome idea. Ram air. faster times, better traps, fuel efficiency, etc.
Then.....I came to realize the design was somewhat flawed in that the seal in between the clam shell design wasn't so sealed. The rubber foam sealing material needs replacement often in dry heat like Arizona, and I believe it wasn't sealing exactly how it was advertised.
That being said, I never had any issues over it either.
Some will argue that torrential downpours will allow too much rain into the intake but keep in mind the rain would have a large distance of travel up the ram air scoops, through the air filter, through the air bridge, and into the intake. If you go nose diving into an 18 inch puddle, yeah....You may seize (hydro-lock) your engine.
If I were to do it again? I may pass on it due to the price, maintenance requirements, and little gains seen/felt/proven.
Your call. Good luck.
Old Apr 30, 2014 | 09:41 PM
sfc rick's Avatar
sfc rick
I had one for a few years, now I'm supercharged. BUT if I ever went back to no supercharger....I'm going to go back Vararam VR-B2 and Powerduct. NOTHING else is even close.
Old May 1, 2014 | 12:09 AM
olbear1962's Avatar
olbear1962
Old May 1, 2014 | 07:06 AM
540i 6spd's Avatar
540i 6spd
I have one on my LT/Cam'd car and have no issues or complaints.
To Vararam VR-B2?
