Prototype: LED mirror turn signal
Old May 7, 2014 | 11:40 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Originally Posted by mrlmd
That's not going to be too bright to temporarily blind the driver at night?
The shorter versions not so much. The 30cm version on my car won't have as much of an effect at night because of my dark window tint.
Old May 7, 2014 | 11:46 AM
703's Avatar
703
Can't wait until these become available. Looks like a great mod.
Old May 7, 2014 | 01:27 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I'd buy some!
Old May 7, 2014 | 01:28 PM
memmer's Avatar
memmer
To answer chasboys question,I haven't removed mine yet but will a little later.One needs to be careful when pulling them out as they can break and that will cost you from $65-$75.00.
Fred
Old May 7, 2014 | 02:46 PM
old stingray's Avatar
old stingray
Now I know what I'm going to do with the red led strips that I got in the mail. Thanks
Old May 7, 2014 | 04:26 PM
Choreo's Avatar
Choreo
Originally Posted by chasboy
Anyone remove a mirror before?
Had to remove mine twice. First time to install my signal mirrors. About a year later the Dealership had to replace my motor packs on both mirrors under warranty (separate issue). When they did that, the Dealership broke both my signal mirrors trying to reinstall them, so I had to order a new set and re-install them myself again. The stock mirrors have a full backing plate with a surround and my signal mirrors do not, so you have to be more careful with them.
Old May 7, 2014 | 04:28 PM
TheRadioFlyer
Supporting Vendor
I will let you know how it goes, but the plan is that you should be able to install the LED strip WITHOUT removing the mirrors from the assembly. You would just need to adjust the mirror to the full inwards position and use a small screwdriver or similar tool to place the strip for mounting.
Old May 11, 2014 | 01:20 AM
mkiv808's Avatar
mkiv808
Seems a bit excessive. I like lighting mods when they look stock. Reminds me too much of Civic's with fake Audi LED strips.
Old May 13, 2014 | 01:29 PM
TheRadioFlyer
Supporting Vendor
After much consideration, I decided to shorten the strip to about half-length. I think the shorter LED strip looks much more classy. I've also found that the are best mounted not to the inside of the mirror housing as originally planned but to the rim of the mirror itself. This allows for easy installation simply by adjusting the mirror full-inward and applying the strip. From there just snake the wire through the housing with the use of a lead-wire and tap into the appropriate wires.
These are the prototype pictures. The LED strip is a little off-set, but it shows the idea. When these are mounted, the top will be even with the bottom.
This photo shows the LEDs in the worst possible light. Even in sunlight, they are still clearly visible and even more so when flashing.
Old May 13, 2014 | 06:57 PM
chasboy's Avatar
chasboy
Oldtimer
George, we're you stating that the strip will be mounted to the reflecting surface of the mirror? If so, what about hiding the wire leads?
Old May 13, 2014 | 07:13 PM
Chicago1's Avatar
Chicago1
I don't know it just doesn't flow well with the car it seems out of place....
I like this though..Choreo where did you get this
Old May 13, 2014 | 10:49 PM
TheRadioFlyer
Supporting Vendor
No the strip will be mounted to the side of the mirror.
Old May 13, 2014 | 11:40 PM
  #33
o2bnkc's Avatar
o2bnkc
Originally Posted by beboggled
I agree. Looks cool! Would prefer they be in red instead of amber.
They must be red if they are facing the rear. Amber if you can see them from the front. USDOT laws.
Old May 14, 2014 | 01:01 AM
  #34
TheRadioFlyer
Supporting Vendor
Not true. Amber can be used for rear-facing turn signal and hazard lights.
Old May 14, 2014 | 07:03 AM
  #35
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
WOW! That's pretty bright!
I may be in on something like this
Anything to keep people who are distracted from running into you or get their attention as you need to make a lane change!
Keep us posted
Thanks,Matt
Old May 15, 2014 | 07:43 AM
  #36
Narco944's Avatar
Narco944
Subscribed
Old Jul 7, 2014 | 09:48 AM
  #37
TheRadioFlyer
Supporting Vendor
Prototypes tested. They work great and are clearly visible during the day because of their position in the dark part of the mirror. Best of all, they can be installed without removing the mirror itself. This product should be available in the production version in late August.
(the driver's side strip was re-mounted to be straight after the vid was taken)
To Prototype: LED mirror turn signal
Old Jul 7, 2014 | 10:11 AM
  #38
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
All the big corvette parts houses used to sell those chevron mirrors. $229. is what I paid 6 years ago. They weren't led at the time and have no idea if they're led now. I got mine from corvette central
Did some searching. $219. and they are hi intensity LED now
Old Jul 7, 2014 | 12:36 PM
  #39
kgie1217's Avatar
kgie1217
St. Jude Donor '14
Looks good George! Will buy when available!
Old Jul 22, 2014 | 03:38 PM
  #40
kgie1217's Avatar
kgie1217
St. Jude Donor '14
Any updates on this?
