[Z06] First Warranty Problem. Leaking posi case.
Old Jul 20, 2002 | 05:01 PM
McRat's Avatar
McRat
Default First Warranty Problem. Leaking posi case.
Well, I made it to 1300mi without a problem. Now the differential case on the driver's side leaks.
If you have had this problem, how long did the dealer have your car?
Old Jul 20, 2002 | 08:19 PM
jonstr's Avatar
jonstr
Default Re: First Warranty Problem. Leaking posi case. (McRat)
Every C5 I've had has had this problem. First my '98, then my '01 Z06, and now my '02 Z06. In each case the problem was fixed in a day, however for the '98 they didn't have the part in stock so it took two trips.
Old Jul 20, 2002 | 08:49 PM
canuckz's Avatar
canuckz
Default Re: First Warranty Problem. Leaking posi case. (jonstr)
After being repaired did the problem re-occur?
Old Jul 20, 2002 | 08:50 PM
McRat's Avatar
McRat
Thanks! I have them look at it Monday. Gotta busy Sat/Sun planned with the Meanie!
Old Jul 20, 2002 | 09:25 PM
figment's Avatar
figment
My power steering pump leaks, been topping it off for the last 2000 miles. Car has 3000 on it:) POS. :smash:
Old Jul 20, 2002 | 11:58 PM
jonstr's Avatar
jonstr
Default Re: First Warranty Problem. Leaking posi case. (canuckz)
I believe I had it fixed a second time on the '98. The '01 was fine out to 10K miles (when I traded it on the '02). The '02 has about 12K on it and no more leaks (so far).
Old Jul 21, 2002 | 05:05 AM
Nestor D. White's Avatar
Nestor D. White
See the Rear Transaxle post on 7/18.
Old Jul 21, 2002 | 11:30 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
McRat,
Our Z06 (6,000 miles) just developed the driver's side differential leak also so I'll be taking it to the dealer this week. Our 2001 Coupe had it happen twice at about the 13,000 mile mark but was fixed the second time and no more leaks since, 23,000 miles now.
Roy
To First Warranty Problem. Leaking posi case.
