[Z06] dreaded column lock hit me
Old May 11, 2014 | 04:06 PM
LT1driver's Avatar
LT1driver
Default dreaded column lock hit me
ok my 03 never had problem until, anyone been able to temp bypass to get to repair shop....is in garage and can't get out as wheels turned, thanks for suggestions.
Old May 11, 2014 | 07:55 PM
c5zee's Avatar
c5zee
The unlock tool can be had here if you don't want to goto a shop (I wouldnt want to pay someone for this easy fix) http://www.complianceparts.com/lmc5unlocker.html
then grab their lmc5 module as well.... http://www.complianceparts.com/lmc5description.html
If you are truly desperate and stranded, I was reading in a thread you can force the wheel "sometimes" by cranking on it really hard, you may have to do a search for the exact "procedure" lol.
Also make sure to fully charge your battery and possibly test it to make sure it's actually good.
Last edited by c5zee; May 12, 2014 at 01:24 AM. Reason: forgot to add link to module
Old May 12, 2014 | 08:27 AM
pit-man's Avatar
pit-man
Yank wheel hard right and turn on ignition at the same time. It may take a few attempts but it will unlock. However, fix it quick...it will lock again.
Old May 12, 2014 | 08:33 AM
rjwz28's Avatar
rjwz28
The CLB was my first mod when I bought my Z I also had the fuel cutoff tuned out just in case the BCM gets confused someday
Old May 12, 2014 | 07:56 PM
sami85L98's Avatar
sami85L98
Just happened to me last weekend at my brothers home when i had absolutely no tools with me nor he has any, well i put the key in, and turn hard right with little impact couple hits and done.
previous owner did installed CLB but i guess after 5-6 years its time for another one.
Edit: happened today as well, yank to right broke loose.......
Old May 12, 2014 | 09:36 PM
916Z06's Avatar
916Z06
Same here, bypass done and one day it crapped out on me so another one it is!
Old May 13, 2014 | 04:33 PM
pit-man's Avatar
pit-man
My friends just went after a year as well. I gave him my un-installed one and he ordered me a new one.
Old May 13, 2014 | 11:39 PM
c5zee's Avatar
c5zee
what brand CLB's are you guys using that have failed?
Old May 14, 2014 | 08:40 AM
pit-man's Avatar
pit-man
I will check...don't remember which one I have.
To dreaded column lock hit me
