Help
Old May 12, 2014 | 06:41 PM
silverbandit's Avatar
silverbandit
Default Help
I have checked and changed everything but the bulbs for my b/u lights and still nothing What am I missing
Old May 12, 2014 | 07:47 PM
65GGvert's Avatar
65GGvert
That was edited for "more info"? Still not enough. Do you have no backup lights? Is it a manual or automatic? What do you mean by checked or changed, what have you checked and changed? If you're working on b/u lights, do they flash when you lock the car? And also, if you put the problem in the title, you'll not only attract people with knowledge on the issue you're working on, you'll be able to search later as will others looking for the same help. There are hundreds of threads with the title "help", or "need help" or similar. Take some time and help us help you by describing the issue.
Old May 12, 2014 | 07:50 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I think the first thing I would of done was check the bulbs and then the fuse.
Old May 12, 2014 | 08:22 PM
More info would sure be nice.
Old May 12, 2014 | 10:41 PM
silverbandit
I'm sorry when I was going give more info I was summoned by the queen (my wife) and didn't get a chance to finish so I will start from the beginning my car is a stick a few months ago my reverse lights and camera stopped working the first thing I checked was the bulbs saw nothing out of the ordinary and when I locked the car they flashed so next I checked the fuse and it was good so I came here for help and someone suggested the reverse switch on the tranny today it got changed and the lights still don't work is there a relay that I'm missing?
Old May 12, 2014 | 11:16 PM
65GGvert's Avatar
65GGvert
Did you check the fuse again after you changed the b/u switch? Maybe it blew. You can eliminate the b/u switch by unplugging the connector and jumping across the two wires in the wiring side of the connector with the key on. They should come on. If not, measure for 12v on one side of that same connector with the key on. If you don't have it, go back toward the fuse box, if you do, go toward the rear. If they flash when you lock, the problem should be in that b/u switch line or fuse. I'd check that fuse very carefully, it usually blows when the b/u switch shorts.
Old May 12, 2014 | 11:19 PM
65GGvert's Avatar
65GGvert
Fuse #21 for the b/u portion.
Name:  b-up wiring.jpg
Old May 12, 2014 | 11:52 PM
zagger's Avatar
zagger
How/where was the reverse camera wire spliced into the system. I would start by tracing that connection first. Try and disconect the HU back up wire from the system then see if the lights will work.
Old May 13, 2014 | 08:59 PM
silverbandit
The camera is spliced in at the reverse lights wiring , I will check these items this weekend when I have the time to do so thanks for the help I will post my findings on monday
To Help
