Regular maintance
Old May 12, 2014 | 09:59 PM
703's Avatar
703
Default Regular maintance
So I'm taking may car in for an oil change and was just curious to see what else I should do. Car currently has 63,000 miles on it.
Also when driving around in 1st/2nd @ 2-3k rpm the car doesn't sound healthy... Not sure how to describe it but it sounds like its working harder than it should. I'm not really sure possibly a belt ?
Old May 12, 2014 | 10:24 PM
chuckeb84's Avatar
chuckeb84
It does depend upon what you have already done.
I do
Brake fluid 2-3 years
Oil yearly or per indicator
Trans fluid depends on driving
Coolant won't last as long as indicated
I would change the belt and tensioner
Plugs Wires
Good Luck
Old May 12, 2014 | 10:29 PM
If the coolant hasn't been changed in the last five years, do that.
Change your brake fluid if it has been more than a couple of years.
Check all hoses and belts for wear and tear - wouldn't want something to go wrong there.
Fuel filter if you do not know when it was done last.
chuckeb84's Avatar
chuckeb84
I do
Plugs Wires
Good Luck
Or
http://www.corvsport.com/Corvette/C5...tSchedule.html
Old May 12, 2014 | 10:36 PM
703's Avatar
703
Thanks everyone, I bought the car used roughly a year ago and the guy did a lot of the maintenance himself so I'm not sure what all has been done other than regular oil changes.
Any ideas on the issue I am having with the engine ?
Old May 12, 2014 | 10:48 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Clean your maf sensor and throttle body, check the condition of the plugs, wires and air filter. When I drove my 01' with 77k mi off the lot it felt like it was down about 50hp until I cleaned the dirty throttle body and maf sensor and changed the plugs and wires and put a cold air intake on...all 350+horses came back.
To Regular maintance
