2002 passenger window not working
Old May 13, 2014 | 10:15 AM
ICD55's Avatar
ICD55
3rd Gear
Default 2002 passenger window not working
2002 z06 passenger window not working.GM shop says issue is internal right front door module, due to updated door module design. Must replace both door modules to repair,and program left and right door modules and program to vehicle.($1475.00) sounds like a bunch of bull anyone have a better solution maybe after market part or junkyard. thanks Bill
Old May 13, 2014 | 10:50 AM
ICD55's Avatar
ICD55
3rd Gear
thank 8vette7, thats why I didnt let them fix it, I appreciate the info.
Old May 13, 2014 | 11:00 AM
c4gone's Avatar
c4gone
that's the corvette tax
Old May 13, 2014 | 11:49 AM
dadaroo's Avatar
dadaroo
The relays are really cheap. If you want to repair it (assuming it is the relays which it probably is) or have someone help you I can get you all the info you need. Not at home now.
If you replace the unit you can still repair the old one.
Old May 13, 2014 | 01:21 PM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We have the door modules for $89 and no need to reprogram. I need the part #.
Marc
Old May 18, 2014 | 08:28 PM
Ron222's Avatar
Ron222
Bill,
Check out the two following links ...you might want to try them before shelling out your hard earned cash. Certainly can't hurt.
http://forums.corvetteforum.com/1567486653-post586.html
http://forums.corvetteforum.com/c5-t...ndow-inop.html
Ron
Old May 18, 2014 | 10:28 PM
sonny557's Avatar
sonny557
Default Module
I replaced mine with modules from Mouser. Less than $2.00 each.
this is showing modules desoldered.
To 2002 passenger window not working
