C5 dot matrix solution
Old May 13, 2014 | 09:11 PM
Bkerling's Avatar
Bkerling
5th Gear
Default C5 dot matrix solution
I am wanting to tint the windows on my C5 but have learned that the dot matrix causes some challenges. The only thing I have seen to deal with this is a black vinyl decal to cover it up. I have a small section of this on my rear window and it is showing signs of clouding but removal of this piece seems to be a nearly impossible since it is a bit brittle and would need to be scraped off. So I kept it there for now. When inside the car looking out of the rear window through the rear view mirror I could just barely see the bottom of the dot matrix on the window. So I decided to tape off the upper section of the window with the dot matrix and kept my tape line along the first defroster element on the window. With the surrounding area protected from any overspray, I painted the dot matrix section of the window. I am happy with the results. I have the same available view in the rear window that I had before only now the dot matrix is not visible. I'm not sure if this will help with my tinting effort but I won't have to deal with the dot matrix now. I will post some pics of the process and results. I'll post some better pictures when I can take it out on a sunny day. Any input or comments are welcome (positive or negative). Thanks for reading.
Old May 13, 2014 | 09:20 PM
jrose7004's Avatar
jrose7004
Looks pretty good really.
Old May 13, 2014 | 09:54 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
That actually looks pretty good. Reminds me of a cockpit window only in reverse. Let us know how it holds up.
Old May 14, 2014 | 07:10 AM
I have heard of some tinters doing that to take care of the dot matrix area. Looks to me like you did a great job.
Old May 14, 2014 | 08:32 AM
Six862m6's Avatar
Six862m6
Not bad at all! I wish I had thought of that before having the windows done on my '04. The guy did a pretty good job on it, but you can still see where the dot matrix is in the tint; he told me there'd be no avoiding it.
Old May 14, 2014 | 09:23 AM
StingrayRebel's Avatar
StingrayRebel
looks good... I had the matrix on my old trans am covered with vinyl and plan to do it on the vette when I get around to retinting them... there is also a glue they can use to help the tint stick to the matrix but I don't prefer that because sometimes it can turn a milky white color once it sets out in the sun
Old May 14, 2014 | 09:34 AM
Dilatedpeoples28's Avatar
Dilatedpeoples28
I did vinyl on mine and it came out perfect. But I have seen were painting works well. If you want something that isn't permanent you can do black plastidip and it does just as well.
Old May 14, 2014 | 02:06 PM
Bkerling's Avatar
Bkerling
5th Gear
Thanks to everyone so far for your input. Now I am just itching to get the tint on the windows and see how well this set up works.
Old May 14, 2014 | 02:11 PM
Bkerling's Avatar
Bkerling
5th Gear
After reading your response, I got to thinking about the section I believe to be vinyl decal. It may actually be plasti-dip and not vinyl. It almost looks like a thick black coating. I was thinking that it was vinyl or tape due to the edge line but that may be where the tape line was and not an actual vinyl edge. Around the electrical connection for the defroster it definitely looks like brush swirl. I'm glad I didn't put a lot of effort into trying to peel it off.
Old May 15, 2014 | 04:28 AM
tintmandevin's Avatar
tintmandevin
Default paint?
Most professional tinters can get the bubbles out of the tint on the paint dots. Whiteness comes from not thoroughly cleaning the paint. Scraping with a razor blade is not enough. You need to scrub with a scratch proof scotchbrite after scraping then clean paint with rubbing alcohol. Tint will stick after that. Its all in the prep.
To C5 dot matrix solution
