2000 corvette
Old May 16, 2014 | 05:33 PM
smglass21's Avatar
smglass21
Default 2000 corvette
since my battery died and haven't started my car in 3 weeks,i put a new battery in and now my retractable lights went up but won't go down,i never had trouble before this.does anyone know about this? thanks
Old May 16, 2014 | 07:47 PM
JR-01's Avatar
JR-01
Try disconnecting battery. Put a full charge on it. Reconnect it.
Old May 16, 2014 | 08:55 PM
Certainly worth a shot to reset the electrical system.
Old May 17, 2014 | 09:16 AM
smglass21's Avatar
smglass21
Default 2000 corvette help
even with a new battery?is there a code for the retractables?i bet it's some kind of circuit ,because it was sitting so long without starting,what about the battery,it's auto zones best,maybe it need's to be delco?when I try to put them down there's I clicking in the fusebox,but fuses ok.
Old May 17, 2014 | 09:36 AM
JR-01's Avatar
JR-01
Did you fully charge the new battery before you installed it? Sometimes new batteries are not fully charged. My car sits all winter without a battery with no issues.
Old May 17, 2014 | 09:53 AM
smglass21's Avatar
smglass21
Default corvette 2000 help
no,i bought it off the shelf at autozone,didn't know I had to,but how come everything else works?
Old May 17, 2014 | 10:59 AM
JR-01's Avatar
JR-01
Seems like a lot of the electronic problems and glitches on these cars are caused by batteries not fully charged. Just a simple thing to check. If you don't drive it for a week or so it's good to put a trickle charger on it to keep battery at full charge.
Old May 17, 2014 | 01:11 PM
smglass21's Avatar
smglass21
Default 2000 corvette i have to take a valium
just got back from advanced auto,they assured me it's fully charged,i changed all fuses and breakers,hand crank them down,put lights on they go right up and stay there,i hope it's not theswitch on the steering wheel,i know on power windows sometimes when a window opener goes it will go one way or the other,being in auto glass I used to run a wire directly to the battery to the plug and the motor would work both up and down once you reverse the wire from battery,that's how we knew it was a opener or switch and not the motor,but this is beyond me
Old May 17, 2014 | 11:27 PM
fsuforever's Avatar
fsuforever
After a period of time the motor/ gears start to wear, u can get some used ones fairly cheap, talk to mark @vettenuts . com & he will have at ur door in a blink, car is 14 yrs old too, stuff starts to wear after a period of time
Old May 18, 2014 | 10:26 AM
smglass21's Avatar
smglass21
I really don't think it's the motors there's no grinding or noise,when I hand crank them down,they go up quiet and no problem,someone wrote ,if it's not fues or circuit,they're replaced,they say maybe the computer is thinking one of the lights are burnt out and keeping them up
Old May 18, 2014 | 10:48 AM
65GGvert's Avatar
65GGvert
Have you disconnected the battery for a few minutes and reconnected it yet? Disconnect it, roll the lights all the way down and then reconnect the battery, see what happens.
Old May 18, 2014 | 12:12 PM
smglass21's Avatar
smglass21
I did that,lights go up and stay,i bet it's something so easy but yet so hard,i cleaned the grounds,i basically did everything I could
Old May 18, 2014 | 12:43 PM
VETJAZZ's Avatar
VETJAZZ
Long shot, but do you have twilight sentinel on? Check and turn it off and see what happens. Good luck.
Old May 18, 2014 | 01:58 PM
smglass21's Avatar
smglass21
thanks 1st thing I checked
To 2000 corvette
