Ground height
Old May 25, 2014 | 10:50 AM
jakecol's Avatar
jakecol
Default Ground height
I've recently bought a 98 hatchback coupe and was wondering how I can determine if it has been lowered by previous owner. Any help would be great. Bottom line is I would prefer it to be stock.
Old May 25, 2014 | 10:55 AM
NHolds's Avatar
NHolds
Put up a pic
Old May 25, 2014 | 11:24 AM
GySgt1811's Avatar
GySgt1811
I have the same question, jakecol, thanks for starting the thread!
Gunny John
Old May 25, 2014 | 11:41 AM
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
is the lowering bolts in back only showing 2-3 threads in the back? And for the front the the bushing will be all the way up top on the leaf spring.
here is a pic of the rear bolt all the way down
And here is a pic of the front
Old May 25, 2014 | 12:24 PM
Lee DeRaud's Avatar
Lee DeRaud
The service manual measurement is not DIY-friendly, as it measures the drop from the suspension mount points to the outer ball joints with a special tool. But stock height is roughly 6" at the front and 6.2" at the rear, both measured from the ground to the bottom of the rocker panel at the corresponding jack point.
EDIT: here's the link http://forums.corvetteforum.com/c5-t...de-height.html
Oh, and each full turn of the bolts works out to 2mm of height adjustment.
Old May 25, 2014 | 02:12 PM
jakecol's Avatar
jakecol
"Thanks" for all of the help folks. You're among the best.
Old May 26, 2014 | 01:22 PM
6speedsteve's Avatar
6speedsteve
This is the proper tool for setting ride height, purchased used on Ebay for $30, new is $300, a Corvette Dealer may be able to reset at stock height.
To Ground height
