C7 wheels on C5
Old May 25, 2014 | 05:44 PM
chuckeb84's Avatar
chuckeb84
Default C7 wheels on C5
Can I get these to fit on my 03 Vert
2014 wheels on my 2003
245/40ZR/18 & 285/35ZR/19
Old May 25, 2014 | 05:48 PM
GTJim's Avatar
GTJim
Do you know what the offsets are?
Edit: Found Them!
2014 C7 Stingray Corvette - OEM Stock Wheel Sizes & Offsets
Base Model:
Front Wheels: 18" x 8.5" +56mm
Rear Wheels: 19" x 10" +79mm
With Z51 Package:
Front Wheels: 19" x 8.5" +56mm
Rear Wheels: 20" x 10" +79mm
Old May 25, 2014 | 05:53 PM
3318C5's Avatar
3318C5
Old May 25, 2014 | 06:26 PM
GTJim's Avatar
GTJim
Won't fit, wheel is too far inward. You may be able to do it with spacers but IMO just buy a wheel with the correct offset.
Old May 25, 2014 | 06:29 PM
chuckeb84's Avatar
chuckeb84
I agree it's been a while since I took Physics and the calculators are giving me a headache.
http://www.corvettecentral.com/wheel-offset/
Old May 25, 2014 | 07:30 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
In time they will make replica's of the C7 wheel with the C5 offset!
Thanks,Matt
Old May 25, 2014 | 08:20 PM
3318C5's Avatar
3318C5
Thanks,Matt
100%, just be patient & you will get what you are hoping for!!
Old May 25, 2014 | 09:20 PM
Good info Jim and I would agree - just be patient and wait for some reproduction wheels to become available in the stock C5 offsets. Probably won't take long.
Old Dec 26, 2014 | 10:16 PM
RedC5's Avatar
RedC5
But this should work the other way around right? If I ever upgrade to C7 base I would like to use my winter C5 wheels and tires. C5 tires should fit as did calculations - virtually same diameter as base C7. Wheel offset basically same up front and rotor size in C7 base similar to C5 front. C5 rear wheels on a C7 will be pushed out a bit from the C7 +79 offset to the C5 +65 offset but this should not be an issue. Am I missing something?
To C7 wheels on C5
