I am talking about the buttons on the unit that controls the heat & air conditioning. My fan speed control button is a bit messed up and I want to replace them with the same factory buttons. I want to know if you can simply pop it off from the front of the unit, or if the unit needs to be disassembled so that they can be removed from inside the back of the unit.
Need to disassemble the unit which is very easy. If you need guidance on how to access the unit for removal here is some great info. Just stop at where you can remove the bezel around the unit.
If you have a manual you really don't need to remove the shift **** and boot. The boot can be rotated and pulled thru the console opening and allow the console removal leaving the **** and boot in place.
Pull off the 2 ***** and unscrew the 4 screws at the back. You will need to then unplug the circuit boards and remove the internal screws as necessary to gain access. Been a couple of years since I have been into one.
i know how to get the unit out of the dash. What do you have to do once you gte it out to remove the controls?
Follow the instructions and pictures in here and you will be able to access the HVAC buttons you wanna replace:
