Factory paint question?
The first step in the process is determining the number of cars to be painted. Paint department personnel puts the vehicles in batches of perhaps 10 cars according to color. Batching the same color cars together is best for the environment and it is obviously more economical to paint all cars of one color at the same time, or as many as possible. It is interesting to note that the body panels are charged electrically before they go into the paint booth. Therefore they attract the paint, which forces it to adhere to the panels more evenly and quicker and with less robotic motion and wasted paint.
Painting a complete Corvette body takes between six and seven hours. The panels arrive at the paint department with a grounding material already applied. (This material is also called a conductive primer.) The first coat applied in the paint booth is a dark grey or white primer. This primer is then baked for about 30 minutes at 265 degrees F. After this dries, any dust or dirt is sanded off. Next, one of eight water born base-coat colors are applied and allowed to dry. These paints are made by Du Pont and when applied, range from .07 mil to 1.2 mil in thickness. After the car panels are painted, they dry to around 80 degrees F, after which a clear coat is applied. Next, the completely painted and clear-coated body panels are sent to the oven where they are heated to about 250 degrees F for between 25 and 30 minutes.
Hope this gives you a good picture.
When repairing a C5, water born paint is not used at body shops because they do not have the extremely costly environmental restraints the factory has to control.
Bill
As a newbie C5 owner (00 vert Navy Blue Met) I have a new appreciation for the quality of the paint finish and I thought I’d add a couple of tidbits.
The clearcoat used on the C5’s was a 2 component system that was mixed inline before application. This resulted in a harder finish than typical 1 component OEM clear systems. I’ve seen many people comment about the especially hard clearcoat when buffing. Also Millennium Yellow, Electron Blue, and Anniversary Red used tinted clearcoats to get a “deeper” color look. They would definitely “batch” these colors as you sure didn’t want Millennium Yellow clearcoat over an Electron Blue basecoat!
Unlike many other OEM painting processes, Bowling Green painted the facia’s (bumper covers, etc..) with the same OEM paint at the same time as the body. This helped provide a consistent color through the complete body. One quirk to this was that sometimes the color looked different between the body and facia even though they used the same paint and process. Pewter was especially difficult. The line between the rear quarters and bumper really showed the issue as they were flat surfaces next to each other.
Even during the C5 days nearly all OEM finishes were waterbased and many refinish shops are now switching to waterbased systems due to regulatory/environmental concerns.
As it happens they converted to this process about seven years ago but according to him the first couple was a nightmare and they were repainting many cars before they got it down.
Although I thought the changeover happened earlier than that: I had a variant of this conversation with the body shop that did one of my cars after an accident in early 2001.
I was just reading about a guy with color problems on a green car, and found they flush the lines between batches, but some paint residue remains in the line and shades some of the paint in the next batch. That is what he reported. He also said his paint supply store had four versions of his green paint, all slightly different shades, all using the same GM color code.
He had about 200 bucks in the almost right color paint. In researching the problem , one dealer told him the color was not GM and must be custom. No wonder GM thinned out the dealers, if this is one of the good ones they kept.
