Rear Differential Fluid
Old May 30, 2014 | 06:08 PM
ironranger's Avatar
ironranger
Default Rear Differential Fluid
I checked with the Chevy dealership and they use Dextron LS 75w-90 Gear Lube that has the additive for limited slip in it.
1) I'm wondering if this is what you're are using today as I looked at some old threads and found other products being suggested.
2) I have around 40k on the car and I change the oil every fall and have changed the coolant last year, but I don't believe the rear differential has been changed. The manual isn't based on months or years, but rather miles, and I have a long way to go to reach that threshold. In prior threads most suggest replacing the fluid for piece of mind while others have suggested not replacing the rear differential until needed as they began experiencing rear end noise "after" replacing the fluid. As a result of several of these posts I have held off.
I would appreciate any comments or recommendations on this. Thanks!
Old May 30, 2014 | 08:35 PM
oh1vette's Avatar
oh1vette
Amsoil here.....
Old May 30, 2014 | 08:39 PM
647m's Avatar
647m
7th Gear
Straight Amsoil, no noise
Old May 30, 2014 | 08:44 PM
spdislife's Avatar
spdislife
Old May 30, 2014 | 09:02 PM
Borntorun04/17's Avatar
Borntorun04/17
ironranger thanks for posting question. I will be looking at responses. I have been thinking of having fluid changed also. Can't see were in any of my paper work on car that the fluid was changed. I have a 04 with 15,000 miles. Concerned with age of oil in differential. I went to a corvette shop and they said they use Dextron with additive also.
Old May 30, 2014 | 09:07 PM
racebum's Avatar
racebum
redline 75-90 here. no chatter, great lockup
Old May 30, 2014 | 09:29 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
I used the Dexron when I changed it two years ago - no noise.
Old May 30, 2014 | 09:34 PM
IH8FORD's Avatar
IH8FORD
I used the ls dextron in mine the other day but I work at dealer so I was able to get it easy.
Old May 30, 2014 | 09:53 PM
ironranger's Avatar
ironranger
Thanks for all of the responses thus far. It sounds like either Dextron or Amsoil will do the job. This is something I will let the dealership do and at this point I will probably be okay with them using Dextron, which they spec out for it.
If anyone experiencing any issues after changing this fluid, let me know!
Old May 31, 2014 | 07:33 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old May 31, 2014 | 03:42 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by oh1vette
Amsoil here.....
Originally Posted by spdislife
+4
Severe Gear 75W-90
Old May 31, 2014 | 04:57 PM
momo20's Avatar
momo20
I run the amsoil stuff in my Z06 and zero issue i love it..and imo much better then the GM stuff
Old May 31, 2014 | 04:58 PM
ROJ#79's Avatar
ROJ#79
Old May 31, 2014 | 08:41 PM
ironranger's Avatar
ironranger
Does the Amsoil have the limited slip additive already in it such as the Dextron, or do you need to add it?
Old May 31, 2014 | 11:28 PM
LoneStarFRC
It already has it, however some cars may need a touch of additive. Most don't.
Btw, it's "Dexron".
To Rear Differential Fluid
