C5 Questions
Old May 31, 2014 | 02:41 PM
always1961's Avatar
always1961
Default C5 Questions
I've got a few (maybe dumb) questions.
(1) Someone told me that when you have HUD it takes a special windshield?
(2) The previous owner installed 19" & 18" C6 wheels on my C5, how far off do you think my speedo is?
(3) When I press the 'Auto' drivers window button I have to hold it on so the window will go up & down. Any thoughts?
Thanks for reading...
Mark
Old May 31, 2014 | 03:09 PM
JR-01's Avatar
JR-01
http://forums.corvetteforum.com/c5-g...placement.html
Old May 31, 2014 | 03:42 PM
always1961's Avatar
always1961
Thanks JR-01
Lots of info there.
Old May 31, 2014 | 04:28 PM
FYRARMS's Avatar
FYRARMS
Wheel diameter has nothing to do with it. How tall are your tires? What size are they?
Old May 31, 2014 | 04:42 PM
always1961's Avatar
always1961
P285/35R19 -26" Tall
245/40R18 - 25" Tall ( I know this one doesn't count)
Thanks,
Mark
Old May 31, 2014 | 04:51 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
Go out on the highway, with your Garmin GPS (or whatever you have). It will give you accurate mph. Compare with your speedometer at 60, 70, etc. You'll know if it's off a little. It won't be much.
Time yourself on the interstate between mileposts. 60 seconds per mile at 60 mph. Compare with your speedometer.
Don
Old May 31, 2014 | 05:19 PM
chuckeb84's Avatar
chuckeb84
Mark
Yes there is a special windshield more expensive for HUD
But owners have used the regular windshield and although not perfect, it works.
Z06 shield is lighter...
Enjoy
Old May 31, 2014 | 05:33 PM
R2R's Avatar
R2R
Don
If no Garmin but a smartphone is available download the App Speed Guage or Speed Hub that you can compare the speedo against. The smartphone App works on the boat too, should you have a boat.
Old May 31, 2014 | 06:14 PM
always1961's Avatar
always1961
Don
Thanks Don
always1961's Avatar
always1961
Enjoy
Old May 31, 2014 | 06:15 PM
always1961's Avatar
always1961
Great advice...
Old Jun 1, 2014 | 11:44 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Regards
Chip
__________________
..................Click for
Old Jun 1, 2014 | 12:23 PM
PhysicsDude55's Avatar
PhysicsDude55
stock rear tire is 275/40/17 which is a 26.6" tire. Get your rear tire size and plug it into a calculator.
I would venture to guess that your tires are the correct size.
Old Jun 1, 2014 | 12:32 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mark
#1. True, But a regular will work, Just not as sharp.
#2. Your speedo will not be off to my knowledge.
#3. You always have to hold it going up for safety reasons, But should go down with a quick tap, If you hold it too long it will stop when you remove your finger .
Old Jun 1, 2014 | 12:33 PM
always1961's Avatar
always1961
Great...Thanks for the advice. How do I figure it with a calculator?
Old Jun 1, 2014 | 12:35 PM
always1961's Avatar
always1961
I'll try not to hold it too long and see if it goes down auto.
Thanks for the help
Old Jun 1, 2014 | 03:03 PM
R2R's Avatar
R2R
Use this one, or one like it. Original tire size should be posted on a label on the car. Plug the OEM numbers in and the ones you currently have to determine speedo effect. But really, the garmin or smartphone app is better.
http://tire-size-conversion.com/spee...r-calibration/
To C5 Questions
Old Jun 1, 2014 | 03:28 PM
always1961's Avatar
always1961
Thanks R2R...At 65 it comes out to 68.02 MPH. But I will try the app as you suggested.
R2R, I did the smartphone app and it shows about 3 MPH faster than my speedo.
Thanks for your insight.
Mark
Old Jun 1, 2014 | 04:15 PM
Mr.Bill's Avatar
Mr.Bill
Thanks for the help
Did this work?
Old Jun 1, 2014 | 04:30 PM
always1961's Avatar
always1961
Did this work?
Bill, Going to try it a bit latter...I will let you know.
Question... Are you close to Summit Racing?
