climate control issue??
Old May 31, 2014 | 06:49 PM
momo20's Avatar
momo20
Default climate control issue??
2003 Z06 Vette!
my when the A/C button is pressed the system blows ice cold A/C as it should, maybe I am thinking about this wrong but the pass side HVAC **** should blow warm air when the dial is turned to hotter temps? right? its not in my case it stay's at what ever I set the drivers side **** too? I checked the DIC and zero codes are present I pulled fuse #27 in the pass side foot well waited 5 mins to let the system reset and the issues is still there any ideals?
Old May 31, 2014 | 07:44 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
The right control doesn't do much. It might change the temp 5 degrees, but that's all.
Old May 31, 2014 | 08:16 PM
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
if you have it on max cold the passenger side will not change. If you have it on say 68 or 70 degrees and turn the heat on the passenger side it will work.
Old Jun 1, 2014 | 03:01 AM
momo20's Avatar
momo20
its too late now to start her up and try it I will try this in the am..i guess I was thinking there would be a significant change between the two sides, but makes more sense now I suppose!
Old Jun 1, 2014 | 12:04 PM
zdeckich's Avatar
zdeckich
2016 C5 of the Year
Let me know if it works. I figured that out when I was at corvetteworld. But as long has you dont have it on max a/c or max heat the passenger side will work.
Old Jun 1, 2014 | 02:48 PM
Old Jun 1, 2014 | 05:19 PM
momo20's Avatar
momo20
I took my car out today and was playing with the climate control and your spot on, tried setting the drivers side at like 68 to 70 and then turned the passenger side to full hot and there temp was only a few degrees difference..thanks !!!
Old Jun 1, 2014 | 07:47 PM
zdeckich's Avatar
zdeckich
2016 C5 of the Year
Happy it worked.
To climate control issue??
