I rarely post a New thread
E.T. Can you shed some light on this?
IN my 13 years here on this forum since retiring from GM, I've rarely started a thread. I've spent most of my time here trying to help people here in open forum with 14,000 plus posts and most importantly in private message with over 20,000 post. With over 30,000 help post under my belt, many of the questions Ive answered over and over and posted hundreds of times to thousands of members, I've never been cynical to anyone asking for help or turned my back.. my only cynicism is that people with no clue about automotive technology seem to think they know better than the guys who design these cars. Their attempts to undermine real answer to real concerns, only confuse those who come here for help. So if the recommended fuel is high octane, then what part of recommended don't you get. If low octane fuel was ok then it would be recommended. Its recommended that you brush your teeth after every meal.. but you don't have too.. but if all your teeth fall out when you are 40, then the point here is not literal. the point is the recommendation is the right choice not a loop hole that an IDIOT can use to further their cheap and uneducated mind can conjure up.. there is a right way and a wrong way to do most things. Car care is something that can cost you now or cost you later. I know people who never change their oil they keep it 3 years, put 30,000 miles on it and trade it in. That is the reason some cars have nothing but problems for the second owner, and the converse is that some members of this forum have 400K + on their C5 and have never had anything internal done to their motor, they use the correct oil, and use the OLM. That's why guys like me have 100,000 miles on their car and it is a strong and visually appealing as it was 16 years ago, and other peoples cars are trashed in the same time. I've seen some awfully pathetic cars that are as old as mine. At 100,000 miles my car is hardly a garage queen, I take it anywhere and park it anywhere but I park smart. Parking smart does not mean taking up two spots either. that's parking dumb. Yet people brag about doing that. So my point here is that not everyone has the same level of intelligence when it comes to their choices in car care or maintenance.. personally I would heed the advice of a Corvette design Engineer who was privy to all the testing that was done and the results of test to fail, procedures.
Also based on your driving habits, you may have a build up of carbon. you could benefit by a top engine cleaner a variant of Seafoam which I think it not legal in Ca. This could lower your compression back to stock. Even a clean motor can reduce combustion temperature.
I will take your advice. I know better anyway.
Fred
I agree with E-T and I seek out 91 octane, 100% dino gas locally. I've never been able to understand why someone will spend thousands of dollars on a "high performance" car like a Corvette and try to save a few pennies on cheap gas. I know a couple of guys who fit that description and they can't explain the logic behind their decision, but they keep doing it. Go figure
OBD
Fred
In this situation, you will see negative effects that could be even worse. Using low octane fuel in a high octane engine will result in severely reduced performance because the engine will attempt to adjust to the lower octane gasoline. In extreme cases, or with prolonged use of low octane gasoline in these engines, pinging or pre-detonation can occur and can eventually destroy your engine. Pre-detonation causes very hot conditions in your engine and can melt sparkplug and pistons.
noun, plural gan·gli·a [gang-glee-uh] Show IPA , gan·gli·ons.
1.
Anatomy .
a.
a mass of nerve tissue existing outside the central nervous system.
b.
any of certain masses of gray matter in the brain, as the basal ganglia.
2.
Pathology . a cyst or enlargement in connection with the sheath of a tendon, usually at the wrist.
3.
a center of intellectual or industrial force, activity, etc.
I hope this is helpful in further queries
Bill aka ET
$uck$
There is this question about the proper fuel to use. My local Sunoco station pumps 60,000 gallons of High Octane fuel a month. A Corvette can use all the octane it can get, especially in the summer. it is much better to use a little more octane and be safe, than it is to use a little less octane and run the risk of detonation and premature engine failure. Those who think or claim they have no issues with low octane fuel are in denial. They just don't know any better and they are ( in the face o Factory design engineering advice )just being cheap and trying to goad as many people into their own cheap mentality about proper maintenance and care, these are the same people that buy 15,000 mile oil and keep it in there for 15,000 miles and they don't care id the oil has the specific heat shielding additive required in a Y body LSX engine which is a bottom feeder and runs a higher run temperature standard... Even your gut has to tell you that there is something wrong with using low grade fuel in a high performance engine. So please don't feed your LSX engine with lawn mower fuel.
Bill aka ET
Some (like the horse led to water), will not drink, no matter the sweet water offered. However, (raised as a farm boy, riding and racing quarterhorses since I was 4 years old), I don't remember ever encountering a horse, without the good sense, to drink...
Don
$uck$
Its easy to put the blame on the seats or the radio, or the cheap plastic, or most of the 6,000 parts we design or overviewed their production from second and third tier suppliers from all over the world, and then all arrive at BG and all fit together and continue the line of American sport car icons, that we all enjoy today.
I have no concern over the loss of any compatible fuel. this simple answer is to have engines tuned for reduced power that will keep the engine in a safe condition, of course this will cost you in performance. You can have a set of after market head made that produce 8:1 compression. There are things that you can do. The solution to your problem would only cause more problems for the greater majority.. If I needed to buy an Alcohol blended fuel right now I would not know where to find it. So you see your solution would require much more overall legislation for a Car that works as design in 98 % of the places it is sold. For those of us who follow the guidelines of the original design, we can keep our car for an easy 300,000 to 400,000 miles as has been documented here. Last time I looked at the mileage registry for a C5 .. here on the forum there was at least a dozen people who have over 400K, there are hundreds registered who come to this forum with 300K +which is a small sampling of the 1/4 million C5 that were built.
I can feel your pain. but your pain is not a gripe felt by the majority of owners, about their C5.
On a similar note for the less fortunate 2% of us who due to the wisdom of our elected constitutes are forced to consume alcohol on daily basis (punt intended) is there a additive product that will not harm our cats and neutralize the ethanol affect in gas we are forced to use. I have used StarBrite additive in my high performance boat engines with great success to subdue alcohol related problems but they have no cats. The only Torco additive available here clearly states not for use on engines equipped with catalytic converters. I personally witnessed the difference high octane alcohol free fuel had on my car during some cross country rallys I did in the past. Aside of averaging 3 more miles per gallon the car felt smoother and stronger. I would not mind spending more or even blending my fuel to get that level of performance back.
