[Z06] Antenna question
Old Jun 5, 2014 | 07:40 AM
mnz06vette's Avatar
mnz06vette
Default Antenna question
I'm considering a shorter antenna. Any comments on size and where to get them. Is reception an issue with them?
Thanks!!
Old Jun 5, 2014 | 02:04 PM
TPA Z06's Avatar
TPA Z06
Not sure if he still sells them, but forum member BitViper used to offer a shorty antenna. That's the one I have and it looks good and works well. It is a semi-flexible rubber mast, probably about 6' - 8" long. Do a search for his name and you should be able to find some old threads where there are some pics of it.
Old Jun 8, 2014 | 10:39 AM
YYZ06's Avatar
YYZ06
I have the one from RPI Designs. FM stations seem to drop off at about the same distance as the original antenna. I live "in town" so I'm not pushing the limit on a daily basis. I'm happy with it.
Old Jun 9, 2014 | 07:00 PM
callie454's Avatar
callie454
I'm running one from Craven Speed Here is a link to a recent thread.
Old Jun 9, 2014 | 10:18 PM
bluestreak63's Avatar
bluestreak63
I've been running this one for quite a while. No issues with reception.
http://www.mamotorworks.com/Corvette...black-612431-1
Old Jun 9, 2014 | 10:30 PM
2003Evo's Avatar
2003Evo
You can always make a shorty out of the one you have...the ball comes out just use pliers and cover the ball with a rag so you dont ruin it...cut the antenna to the desired heigh then glue the ball back on
Old Jun 10, 2014 | 12:25 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
I believe the length is best cut to specific size, I'll see if I can find a reference.
By the way, I don't think Bitviper uses that screen name anymore. Try SDZ06, I think...
Old Jun 10, 2014 | 12:42 AM
Robby04's Avatar
Robby04
I got one from bitviper only a few months ago. It's not bad. Quality of actual antenna is good. And it works the same as the stock one. However you have to trim off some of the plastic on the bottom. It's not a big deal. But It really annoyed me. Because nobody talked about that and it wasn't in his description. It took a while but I got it perfect with a razor blade...
Cutting the stock one is lame. IMO.. I always rather keep the oem parts nice and stored.
Do get one fitted for GM threads. Those cheapy ebay ones suck.
To Antenna question
