Sway Bar, End Link, Shock Install
Old Jun 5, 2014 | 08:06 AM
VETTEC599's Avatar
VETTEC599
Default Sway Bar, End Link, Shock Install
I am upgrading the sway bars, end links, and shocks on my '99 FRC. Can the bars and end links be replaced with the car on ramps? I do not have access to a lift; however, have decent mechanical ability. Torque specs?
Old Jun 5, 2014 | 08:24 AM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
http://www.toquez06.com/c5torquespecs.html
Old Jun 5, 2014 | 09:48 AM
NukeC5's Avatar
NukeC5
Bars and endlinks are probably the simplest modification you can do on these cars. You'll be fine on ramps.
Old Jun 5, 2014 | 10:02 AM
Sox-Fan's Avatar
Sox-Fan
http://forums.corvetteforum.com/1576253367-post32.html
Old Jun 5, 2014 | 12:38 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Easy to do the bar on ramps. I did mine a few times.
The end links have a torx head on the bolt that needs to be controlled while undoing the nuts. I did not have the right size and had to buy one. (sorry, but I don't remember the size)
Front
Stabilizer Shaft Insulator Clamp Bolts = 43 lb ft
Stabilizer Shaft Link Nuts = 53 lb ft
Rear
Stabilizer Shaft Insulator (Lower) Clamp Nut = 70 lb ft
Stabilizer Shaft Insulator (Upr) Clamp Bolt = 49 lb ft
I haven't done the shocks on mine yet, but the torques are below.
Front
Shock Absorber Lower Mounting Nuts = 21 lb ft
Shock Absorber Upr Mounting Nut = 19 lb ft
Rear
Shock Absorber Lower Mounting Bolt = 162 lb ft
Shock Absorber Upr Mounting Bolts = 22 lb ft
Good luck.
Old Jun 5, 2014 | 05:04 PM
dss's Avatar
dss
You can do it with ramps but it is much easier on jack stands and the tires off the car so you can access the end links easier.
To Sway Bar, End Link, Shock Install
