Run Flat or Not, that is the question
Old Jun 9, 2014 | 01:05 PM
Methods76's Avatar
Methods76
3rd Gear
Default Run Flat or Not, that is the question
I currently have 2 good run flats on the rear and am in need of new front tires. Would it be noiser and a rougher ride if I DO NOT put run flats on the front wheels?
Old Jun 9, 2014 | 01:17 PM
CQRT's Avatar
CQRT
Non-runflats are generally quieter than runflats because of the stiff sidewalls. They're also about half the cost.
There have been a ton of postings and discussions about the wisdom of running runflats and non-RF together- but as long as you don't mix/match on the same axle, I'm not sure it's an issue.
Use the search feature if you want to read other comments - - there are other folks that think running to different types of tire constrauction's a bad idea.
Just my .02-
Old Jun 9, 2014 | 01:21 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You can't mix the technology, ( actually you can but its not recommended and a perfect opportunity to lose control. ) Many shops will not mix run flat and non run flat technology. The side wall of a run flat is not as forgiving as a conventional tire and only gets stiffer and harder as time goes on. .
Old Jun 9, 2014 | 01:41 PM
RedZMonte's Avatar
RedZMonte
NON run flat and an inflation/mobility kit... AAA just as a backup.
S
Old Jun 9, 2014 | 01:53 PM
LoneStarFRC's Avatar
LoneStarFRC
S
There ya go. I would not however, mix RF w/non-RFs.
Old Jun 9, 2014 | 02:19 PM
I personally would not mix runflats and non-runflats. Heck, for the price of two new runflats, you can just about buy a complete set of non-runflats. Look at the Hankook Ventus V12 EVOs - they can be had for around $650 for a complete set.
Old Jun 9, 2014 | 02:22 PM
Methods76's Avatar
Methods76
3rd Gear
Thanks Jack!!
Old Jun 9, 2014 | 02:24 PM
Methods76's Avatar
Methods76
3rd Gear
Thanks everyone...now I have a decision to make cause I have 2 slightly used run flats on the Vette and I don't want to mix technology, nor do I want to just take off the run flats and spend money on 4 tires instead of 2..... Oh well I guess, I asked!!
Old Jun 9, 2014 | 03:27 PM
CQRT's Avatar
CQRT
You might be able to peddle your two Runflats on local Craig's list to recover a little dough . . . a set of 4 Nitto 555's- a good choice-- would run $725 out the door at Discount Tire or one of the other big chains--- just as a comparison.
You might also help yourself by adding your city to your profile . . never know, someone might want your old tires if they're close.
Good luck-
Old Jun 9, 2014 | 04:36 PM
cessna10's Avatar
cessna10
cesssna10
S
That seems to be the thinking of the vast
majority on the forum
Old Jun 9, 2014 | 05:18 PM
aj98's Avatar
aj98
IMHO I'd rather pay a bit more for runflats and turn up the radio to compensate for the noise than have to buy a new set of rims in the event of large pothole or similar.
Old Jun 9, 2014 | 07:53 PM
jp6ivy's Avatar
jp6ivy
Cruising
Just replaced 12 yr. old runflats with Hankook Ventus V12 Evo2 and a repair kit last week. Amazing difference.
Old Jun 9, 2014 | 07:55 PM
NukeC5's Avatar
NukeC5
Not to runflat.
You will have a much more rewarding ride and save money on tires.
Old Jun 9, 2014 | 07:59 PM
Fcar 98's Avatar
Fcar 98
At the age of 60, I prefer the run-flats.
Old Jun 9, 2014 | 08:03 PM
frsr06's Avatar
frsr06
:agree:I dread the thought of being stuck on the side of the road...
Old Jun 9, 2014 | 08:18 PM
NukeC5's Avatar
NukeC5
AAA should be a no brainier for the elderly...
Old Jun 9, 2014 | 08:25 PM
joe's98's Avatar
joe's98
St. Jude Donor '15, '17
I have some run flats that are getting old. Just priced Michelin A/S3's out the door at Costco for $950. I already have AAA that has never been used, hopefully it will stay that way.
To Run Flat or Not, that is the question
Old Jun 9, 2014 | 08:32 PM
F&Yb0dluvr's Avatar
F&Yb0dluvr
non runflats and a $15 tire inflator kit at walmart is my vote. Pocket the price difference for some mods, and enjoy the quieter ride, better grip and longer wear.
Old Jun 9, 2014 | 08:37 PM
Fcar 98's Avatar
Fcar 98
I have aaa, not a good thought wanting them to tow the vette.
Old Jun 9, 2014 | 08:39 PM
NukeC5's Avatar
NukeC5
Ive had it done several times. They use a flat bed. Its not tugged along rolling on the ground.
