DIC throws every code in the book
Old Jun 10, 2014 | 05:34 PM
HeyVern's Avatar
HeyVern
From: Grace Valley: A small, peaceful & beautiful valley in the Volunteer State
Default DIC throws every code in the book
2003 C5. DIC shows every possible problem, Service Vehicle Soon, Service Act. Handling, Service Traction System, Reduced power, Shocks Inoperative, Service Ride Control, plus fuel and oil pressure gauges go to zero (both fluids levels OK) and then go to normal and then back again. Same with engine temp except it pegs at high end.
When I pull the codes up, every major and subgroup have 1-5 codes listed.
The only thing I've done to the car is install new DLR housings (the originals had holes burned on the top) with LED bulbs. Everything was OK except for the hyperflash. Then I installed the hyperflash bypass and everything went to hell.
I guess I only have 1 choice--remove the bypass and see if all goes back to normal. Of course it could have a coincidence, but,,,,,,,,,,,,
Old Jun 10, 2014 | 09:19 PM
ourblk96's Avatar
ourblk96
Check your grounding points throughout the car.
Old Jun 11, 2014 | 09:52 AM
3sACROWD's Avatar
3sACROWD
Disconnecting / reconnecting the battery can throw codes but I don't remember ever hearing them causing the dash to go crazy. 8VETTE7 gave you a link to follow. If you pull the hyperflash unit and still have the problem and your passenger floor is dry, you might consider checking the connections that are near the accordians in each door. Bad connections there will make your IP squirrelly too.
To access, open the door and separate the accordian from the chassis side. Pull on the wires going into the chassis and you will find connectors there. Verify the pins are clean and tight. Bill Curlee did a write up on this as well. It took me less than 30 minutes to do both doors and it fixed my issues with warnings and codes.
Old Jun 11, 2014 | 10:39 AM
HeyVern's Avatar
HeyVern
All great suggestions. But my problem was my Window Valet. I just remembered several years ago having the same massive problem and for some reason took my WV out. Rather than trash it I just put it in the glove box. So here came summer and I have a Vert, So being able to lower all windows as you approach the car makes it easier to unlatch the top. It worked OK until two days a ago. I remembered this problem this morning, pulled the WV and all is back to normal.
Old Jun 11, 2014 | 10:59 AM
Bill Vett's Avatar
Bill Vett
I had the same problem it was the wires in the drivers door. Pulled the accordian tube fish out the bundle of wires from the door and the a pillar, clean all contacts at each connector put back together and you should be ok.
Old Jun 11, 2014 | 11:03 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by 8VETTE7
I would certainly remove that to see if the issue goes away, but I suspect the problem will remain or come back..... The following link:
http://forums.corvetteforum.com/c5-t...-there-is.html
Is what I would be reading..........
It certainly sounds like this is going to be your best course of action - going in reverse of what you installed and identify what is going on!
More than likely a short is happening in your new Hyperflash unit!
Keep us posted on your findings.
Thanks,Matt
Old Jun 11, 2014 | 11:07 AM
envyz06's Avatar
envyz06
Old Jun 11, 2014 | 01:03 PM
3sACROWD's Avatar
3sACROWD
Thanks for posting your findings. So many people don't close the loop. I learned something new today. I'm glad you found your problem.
Old Jun 11, 2014 | 11:11 PM
OP - please do post up what you ultimately find as the cause of the messages on the DIC.
To DIC throws every code in the book
