Catch can hooked up right?
Old Jun 10, 2014 | 08:21 PM
Narco944's Avatar
Narco944
Default Catch can hooked up right?
Just wanna make sure. Car is a 98 and is running fine. It's a CCA can.
Old Jun 10, 2014 | 08:32 PM
GoldenFlame's Avatar
GoldenFlame
Looks right to me
Old Jun 10, 2014 | 08:33 PM
Looks to be hooked up the same way my Elite Engineering catch can is.
Old Jun 10, 2014 | 09:17 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Same - that's how I hooked up my E2 can on my '97
Old Jun 10, 2014 | 09:34 PM
robert miller's Avatar
robert miller
Old Jun 10, 2014 | 10:37 PM
Narco944's Avatar
Narco944
Sweet. Thanks gents!
Old Jun 11, 2014 | 08:56 AM
Mickeyrx70's Avatar
Mickeyrx70
The plumbing is the same as my EE catch can, but mine sits 2"-3" lower. Probably different bracket design.
Old Jun 11, 2014 | 09:22 AM
bjones7131's Avatar
bjones7131
Someone educate me on why U would go to this system. Does it eliminate the PVC valve system? What are the advantages of this system over stock system? Thanks
Old Jun 11, 2014 | 10:28 AM
Dcollins3208's Avatar
Dcollins3208
It's really the same system, you're just adding a piece to it. PCV valve stays, then you install catch can between the PCV and intake manifold port. Our engines are notorious for sucking oil into the intake through the PCV system. Catch cans help alleviate most of this.
Old Jun 11, 2014 | 10:57 AM
Narco944's Avatar
Narco944
Mickey,
I could have slid the can lower or higher in the bracket. It's adjustable.
Old Jun 11, 2014 | 11:29 AM
bjones7131's Avatar
bjones7131
Is the presence of some oil in intake bad and for u that have this system does your vette operate/perform better.
Old Jun 11, 2014 | 11:37 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Scroll down and read the explanation here...
http://www.eliteengineeringusa.com/e...ing-catch-can/
Old Jun 11, 2014 | 12:25 PM
6speedsteve's Avatar
6speedsteve
When I purchased my 2003 in 2010 it had 5300 miles, these are the photos when I removed the intake for cleaning. I now use a catch can.
CLEAN NOW
Old Jun 11, 2014 | 01:10 PM
Mickeyrx70's Avatar
Mickeyrx70
Originally Posted by Narco944
Mickey,
Of course. Duh .. I'm .
Old Jun 11, 2014 | 01:52 PM
Narco944's Avatar
Narco944
I had no personal experience with oil getting in to the manifold, I just know the LSx's are notorious for that happening. I picked this up for a really good price. I figured why not? Be proactive about things so that no problems pop up down the road.
Old Jun 11, 2014 | 01:56 PM
c4gone's Avatar
c4gone
how long does it take to install one of these and do you have to be mechanically inclined?
Old Jun 11, 2014 | 02:00 PM
Narco944's Avatar
Narco944
Easy to install. Took maybe 15 minutes. Remove the FRC, pop the hoses on, tighten the clamps, put the FRC back on. Anyone can do it.
To Catch can hooked up right?
