Headlight Upgrade?
Old Jun 15, 2014 | 02:37 PM
shaps-mn's Avatar
shaps-mn
1st Gear
Default Headlight Upgrade?
I am thinking about changing the headlights on my 2004 C5. Looking for input...does anyone have any experience with the Sun Gun Projector System for JW Motorsports. Also am open for any suggestions.
Thanks...
Old Jun 15, 2014 | 02:46 PM
thealien's Avatar
thealien
This should be a GOOD STARTING POINT
Old Jun 15, 2014 | 09:44 PM
JETZ's Avatar
JETZ
'The Radioflyer' is your answer!
frank
Old Jun 15, 2014 | 10:26 PM
dubtrub's Avatar
dubtrub
It seems that your hyper link is invalid.
Old Jun 16, 2014 | 12:37 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
frank
You are too kind.
Our Bi-xenon projector headlights provide the greatest output and sharpest look in a bolt-on setup. We have two styles of headlights, one retains the pop up look and the other the more modern fixed headlights.
Our pop up system:
http://shop.radioflyerinnovations.co...lights-015.htm
Our fixed headlight system:
http://shop.radioflyerinnovations.co...lights-007.htm
Both systems use 55w HID light source in a high quality Bi-xenon projector to produce phenomenal output especially compared to the factory lights:
Old Jun 16, 2014 | 12:43 AM
dubtrub's Avatar
dubtrub
It say's "pop up look". Maybe I'm dense or misreading that statement but do the headlights still rotate up and down as normal with factory lights?
Old Jun 16, 2014 | 12:48 AM
TheRadioFlyer
Supporting Vendor
Yes, you are correct. The Bi-xenon ACA headlights open and close using the same factory mechanism. Only the reflector housing gets replaced. The rest of the factory headlight system remains.
Old Jun 16, 2014 | 12:49 AM
dubtrub's Avatar
dubtrub
Sounds great! Thank you!
Old Jun 16, 2014 | 02:32 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
You are too kind.
Just bought the headlights from this vendor. Shipment came on time as promised (13 days).
Looking forward to having them installed.
Can anyone suggest a Corvette mechanic who could install them? I am located in the Washington DC, Maryland, Virginia area.
Thanks.
Old Jun 16, 2014 | 10:50 AM
ChuckWalters's Avatar
ChuckWalters
You are too kind.
George, your webpage lists the HID light source for the Bi-Xenon kit as 70w but above you have 55w???? Can you clarify?
Old Jun 16, 2014 | 12:12 PM
MAC5's Avatar
MAC5
I have George's system installed on my C5, if I recall the ballasts are 70w and the HID bulbs are 55w.
I'm sure he'll chime in to clarify.
Old Jun 16, 2014 | 07:06 PM
thealien's Avatar
thealien
I tested it yesterday when I posted it and it worked? It was just the search results from "sun gun projectors". There was quite a few hits.
To Headlight Upgrade?
