Found this works on all kinds stuff... Was power washing wheels brake dust Etc. wheel weight fell off... Loctite Super Glue ,head liner on drivers side on the edge was comeing down fixed, little tear in seat fixed .. I found all kind uses for this stuff drys realy FAST and will glue your fingers togeather right now...Went to track 135 MPH wheel weight still on..Just a FYI...
Took a door panel off the other day and of course broke the mount for one of the pins. Little super glue fixed it right up and it didn't break when I had to take it off again yesterday yay!
What the heck are those stupid little panels behind each of the door handles? I knocked them both off within the first month or two that I had my car just by grazing them with my fingertips as I grabbed the door handle... of course, half the tabs broke off
I think there is a screw behind the little deal ..I got one from I think E-Bay 2-3 bucks ....Don't glue it will need to get to something behind in little deal if you ever need to take the panel off..
That's what I was thinking. What did you call it when you searched for it?
Behind those panels are two screws that need to be removed in order to take the door panel off.
I was looking for something a BAM there they were I needed one and got 3 it's been about a year ..The new ones stay in ..The dealer may be the way to go if still can get them...Could not realy see it but I knew it was gone...
Her we go ,Corvette Door Pannal Access Cover Plug C-5 .. EBAY $4.15 just seen one ... Hope this helps I would get 2-3 what way will never come off if have on to put back on ..That the way it works for me anyway...
Thanks, bro it drove me nuts when those tabs broke and the covers fell out
I have had at least 4 of those just fall off the door with broken tabs over the 8 years i've own my car and every one where quality GM factory parts LOL if that tells you anything. Speaking of, I need to order more now because it broke when i took the door off apart the first time. make the count 5 now. And yes there are 2 torx bit screws behind that little plug you must remove to take the door off, among other things.
