How does your M6 feel?
Old Jun 19, 2014 | 02:53 AM
travbjork's Avatar
travbjork
Default How does your M6 feel?
So.... the manual six speed in the Vette feels very.... mechanical.
To the point it almost worries me.
Between the death clatter (if you turn the car off without depressing the clutch) to the often difficult shift gates, it's a rough transmission. No problem with slippage or actual shifting or clutch grip though.
It makes odd noises at slow speeds. When I shift from first gear at a low rpm, it's kinda death clattery if it's done too slowly at really low speeds.
This is my second C5 (it's a 2003), but my first manual C5... and the last manual I drove was a 2004 M3 about 5 years ago.
Am I just being paranoid or is this all normal? I drive very conservatively 99.9% of the time, I'm 25 years old. If I'm being an ******* to my car, then sure, it feels like a Corvette and awesome and great and sporty...
Mostly just curious if this sounds like everyday drivetrain stuff for the model or if I should work on some maintenance. This may have been covered before, but it's pretty personal, being a gearbox and all, so was looking for personal answers/questions.
Should I think about clutch fluid change?
2003 Corvette M6 Convertible, black on black, with 50k miles.
Thanks for the advice guys!
Travis
Old Jun 19, 2014 | 03:27 AM
travbjork's Avatar
travbjork
Originally Posted by 8VETTE7
Sounds pretty normal to me. If you change the trans fluid to Amsoil Torque drive or Royal purple or some other good synthetic product it will get a little better but they will still be pretty noisy and notchy to shift.
I would use the Ranger method to exchange the clutch fluid especially if it is very black:
Take Care of Your Clutch--the Ranger Protocol - YouTube
Wow, that seems super easy. And mind you, stupid question, I've checked my fluids, but I'm in my office... the clutch master cylinder is on the drivers side near the brake fluid, yea?
Old Jun 19, 2014 | 03:38 AM
travbjork's Avatar
travbjork
Yes. I should mention that it will take significantly more than the one iteration shown in the video if your fluid is really black. Pick up plenty of fluid BEFORE you start.
Yes yes, of course of course, I'd probably even do it right there in Autozone's parking lot if it's actually that easy, and they'd dispose of old fluids for me. It's dark here in Texas, so can't check now... to be honest the only problem I really had was the noise and shift gates.
Don't wanna go breaking any plastic forks!
Old Jun 19, 2014 | 07:04 AM
The C5 6-speed does have a marbles-in-a-can noise under slight acceleration - that is normal. And many complain about the notchy feel of the shifter. You can always get an aftermarket shifter and make the car shift smoother.
Old Jun 19, 2014 | 10:42 AM
john8642's Avatar
john8642
The C6 shifter makes a big improvement over the stock C5 shifter. One of the best mods I've done.
Old Jun 19, 2014 | 10:56 AM
acroy's Avatar
acroy
My 2000 FRC has the original M6 with 130k and 500whp going through it.
PO's and myself have treated it well - shift nice and easy, no abuse. It feels mechanical, but no nasty noises. At least nothing I can hear over the straight pipe exhaust 6th is a bit recalcitrant but otherwise, no issues.
I highly suggest quality fluids in the diff & trans for noise & wear reduction. Clutch fluid is a good maintenance item but won't change trans noise.
Shifter: mine is a shortened stock shifter with a Hurst ****. It's nice. aftermarket shifters replace the shifter only; does not change the mechanism/linkage at all.
You can reduce the notchy feel by the anti-Venom mod:
http://www.toquez06.com/avm.html
basically reduces the spring pressure around the detents. It's good to do the alignment procedure on the shifter as well, it's pretty easy.
Best of luck!
Old Jun 19, 2014 | 11:02 AM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Yep - This will do it! The Amsoil Troque drive makes an amazing difference. The M6 has always been notchy at best. The Ranger method also works very well to clean up the clutch fluid. Zuti
Old Jun 19, 2014 | 03:38 PM
540i 6spd's Avatar
540i 6spd
Travis
Mine does the same. Install headers and a cam.... no more rattle sound from the drive train as both mods drown out the chatter.
Old Jun 19, 2014 | 04:29 PM
troyguitar's Avatar
troyguitar
The C5 shifter and trans are pretty clunky compared to most of the German and Japanese manual transmission experiences for sure. They don't seem to actually break any more often, they just feel/sound worse. It's one of the compromises made by GM to achieve so much performance per dollar.
Old Jun 19, 2014 | 05:59 PM
vetteguy8's Avatar
vetteguy8
Yes mine feels like that also! this is my third C5 and they all felt like this ! every morning I start the car, take off and I just hate it in first gear especially !! sounds clunky at low speed, then second gear I try to go a bit higher in the rpm's and its ok after that ! I had a 328I BMW 5 speed also (sold now) and this thing had the best shifting transmission I ever had in my life ! BUT of course I love the Vette way more !
To How does your M6 feel?
