C5 exhaust
Old Jun 22, 2014 | 05:23 PM
ram01's Avatar
ram01
Default C5 exhaust
Do C5 have 2 catalytic converters from factory.And does anyone have pics of complete exhaust under car.thanks
Old Jun 22, 2014 | 07:30 PM
williame3590's Avatar
williame3590
No photos but yes two cats.
Bill
Old Jun 22, 2014 | 08:28 PM
ram01's Avatar
ram01
Bill
So it is true duel exhaust.
Old Jun 22, 2014 | 08:31 PM
Chicago1's Avatar
Chicago1
either 2 or 4..
http://forums.corvetteforum.com/c5-t...ls-within.html
97 - 99 have 1 main cat on each exhaust.
The majority of 00 are just like 97 - 99.
NE and CA Emissions 00 model year C5's have pre-cats at the end of the exhaust header.
2001 - 2003 LS1's and 2001 LS6 have the same precat configuration as 00 NE and CA Emissions.
2002 - 2003 LS6 removed the precats and went with a larger more efficient set of main cats.
If you remove the precats, you do not need O2 simulators. If you remove the main cats you do need after cat O2 simulators.
The C5 has O2 sensors before the main cats that perform engine feeback control during non-wot. And a set after the main cats, soley to determine main cat functionlity.
Old Jun 22, 2014 | 08:50 PM
Burkdog62's Avatar
Burkdog62
Not to hijack the thread but I have a similar question about the exhaust set up. I use to be a Mustang guy so I understood the exhaust configurations (x or h pipe with shorty vs longtube headers).
I will probably want to get an off-road x pipe before I put longtubes on the corvette so my question is if I get an x pipe now will it work down the road with future long tubes or will I have to purchase a matching x pipe that will hook up to long tube headers?
Old Jun 22, 2014 | 09:05 PM
Outlawtorn's Avatar
Outlawtorn
You will need a new x pipe that pairs up with your long tubes...as they vary in length. My corsa exteme x pipe matched up with the stock exhaust but wont fit my ARH longtubes... I had to get the matching offroad pipe from ARH
Old Jun 24, 2014 | 07:49 PM
Burkdog62's Avatar
Burkdog62
Thanks for the info!
Old Jun 24, 2014 | 09:32 PM
Good info, Chicago1.
To C5 exhaust
