temp range?
Old Jun 23, 2014 | 06:17 PM
t tom's Avatar
t tom
Default temp range?
posted these questions in C4 section by mistake, 03 has been running up to 260, does come down to 240 when clear traffic, is that too high, fluids seem topped off ok, also , this is a convertible and yellow button you release deck with only works intermittently, most of time I have to pull release cable!!! pain in the butt, any ideas, or anybody else had this problem? thank you for any help, Tom
Old Jun 23, 2014 | 06:31 PM
260*, even 240*, is too high. Your car should run around 190-200* on the road and maybe 220-225 in stop and go traffic.
Check to see if you have a lot if debris in the radiator area and if not, you will have to check other possibilities like stuck thermostat, bad water pump, collapsed hose, clogged radiator, etc.
Bill Vett's Avatar
Bill Vett
Clean the radiator, these cars are bottom breathers, just last week there was a similar thread.
http://forums.corvetteforum.com/c5-g...-radiator.html
Old Jun 23, 2014 | 06:44 PM
Chicago1's Avatar
Chicago1
lots and lots and lots of threads like these. Just do a search and you will be gtg..Did I mention there are alot?
Old Jun 23, 2014 | 10:18 PM
t tom's Avatar
t tom
thank you! much appreciated , will blow it out tomorrow
Old Jun 24, 2014 | 09:09 AM
Bill Vett's Avatar
Bill Vett
Every fall before I put the car up for the winter, I clean the radiator and the udders. Have never had over heating or wiper motor problems.
To temp range?
