C5 Corvette Nexus 7 tablet install (Build Thread)
Old Jun 26, 2014 | 10:25 AM
StopHammertime's Avatar
StopHammertime
Originally Posted by StrangelovesM6Vert
I used my Galaxy Note 2 as the clip in stereo head unit.
Another place to put the 1/2 din is on the side of the trans tunnel.
I have a rare old school Kenwood 9042 digital eq and old school Rockford 500a2 and 600a4
amps.
Is your EQ connected to the factory stereo at all, or anything? How is that thing wired? I am considering doing an external antenna setup, and figuring out FM radio on the tablet so I can get rid of the single din head unit, but I haven't found a solid option for that just yet.
Old Jun 26, 2014 | 11:41 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Yes the phone is connected to the factory stereo using the CD as an aux input through an adaptor but you can also just do the $3.00 aux mod to the factory deck.
I use the stock volume ****.
There's also a PAC adaptor that gives me front and rear RCA outs for the amps. I run the front RCA outs into the EQ and then to the amps.
http://www.ebay.com/itm/PAC-97-04-Chevy-Corvette-Aftermarket-Amplifier-Amp-Add-On-4Ch-RCA-Interface-/390693617163?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item5af7277e0b&vxp=mtr
Old Jun 26, 2014 | 02:47 PM
tdogg21's Avatar
tdogg21
2017 C3 of Year Finalist
This is awesome! I've been thinking about doing the same thing but with an iPad mini. Basically the same concept and same size, just different OS. The cost/benefit is just so great, it's almost a no brainer. You get more features than you do with a Double-Din unit at a lower cost. And to top it off, it looks much better.
I was thinking about just mounting the mini in front of the stock radio and hard-wiring to the radio. But my biggest problem is I don't know if I can. I tried to add an iPod hookup to my radio a while back and it wouldn't work. I had everything torn apart and wired up, but I couldn't get my radio to switch to AUX. Dennis from DD mods was great and we troubleshooted by email until late into the night, but in the end it looks like it's my radio. I thought about getting a single din radio with bluetooth or an aux input, but I didn't want to mount that in the dash. I never thought about mounting the radio somewhere else and mounting the tablet in the dash. The only drawback I see is removing the tablet. I'm not sure I would want to leave in there all the time. It would be nice (especially in the winter) to be able to take the tablet out for regular use.
Good luck with the fine-tuning of your install!
Old Jun 26, 2014 | 03:06 PM
StrangelovesM6Vert
You don't even need a radio head unit if you can live without the radio.
I put this 7" Galaxy tablet into my daily driver 2004 Lincoln LS 3 years ago and used a headphone out to rca in cable.
I took out the radio and fabricated out of aluminum something to hold the tablet.
It is hinged and held in place with velcro and can be removed.
The EQ is behind the tablet.
I use the tablet volume control and just leave it on standby dimming the screen so it comes on instantly.
Something like this could be fabricated for the C5.
Old Jun 26, 2014 | 08:02 PM
JMG2's Avatar
JMG2
Moderator
if you absolutely want radio and don't want to use the head unit you can: (1) use iheart or tunin (assuming you have internet access through your tabl) (2) get a Bluetooth fm radio module (extremely cheap) or (3) use a different tab with built in fm receiver, like a Samsung ... although their "mini" is an 8"....
Old Jun 27, 2014 | 09:18 AM
tdogg21's Avatar
tdogg21
That's interesting. I like it. I have no need for FM radio. I've had satellite radio for almost 10 years. The only time I listen to FM radio is when I'm at the beach. And only because it mixes things up a bit and I like hearing the commercials to hear what's going on around the area.
So I'm assuming I would need to wire the speakers to an amp and then the amp to the EQ, correct? I sold all of my aftermarket audio equipment with my last custom car, so I would need to buy all new stuff. In the long run, it might be easier and cheaper to relocate my stock radio or some other option. Any thoughts on that?
Old Jun 27, 2014 | 10:37 AM
StrangelovesM6Vert
You could hook up a phone or tablet to your existing car stereo using an adaptor that utilizes the CD setting for an AUX port or if you do the $3.00 CD Aux port mod.
You can only use an external EQ if you have aftermarket amps.
Old Jun 30, 2014 | 03:32 PM
tdogg21's Avatar
tdogg21
What's the "$3.00 CD Aux port mod"?
Old Jun 30, 2014 | 03:53 PM
StrangelovesM6Vert
http://ls1tech.com/forums/stereo-ele...t-adapter.html
Old Jul 15, 2014 | 01:14 PM
StopHammertime
Bump.
I may be interested in selling this entire setup to any interested parties. I am testing the waters on selling my car (http://denver.craigslist.org/cto/4570112382.html for anyone interested). I may sell all this stuff and return it to a single din setup so the buyer doesn't have to worry about the tablet and all the learning curve involved.
If anyone is interested, I would sell the tablet, double din bezel, cables, PC fan for cooling behind the tablet, for $500 shipped + your factory radio bezel. Pretty good deal considering the bezel alone is $280, plus wait time, and the tablet is $270ish.
