c5 alternator charging issues
Old Jun 25, 2014 | 10:06 PM
xtremeironworks's Avatar
xtremeironworks
Default c5 alternator charging issues
Hello All,
I just upgraded my 2004 LS1 engine with Port polished 243 heads, Lunati cam, long tube exhaust, Air Raid CAI, Stage 3 Transmission, and some small other items. Also had Professionally tuned/Dyno by Nic D (Excellent professional guy). I also had my water pump, valve covers, and alternator bracket powder coated. Here is the issue. I have to rev the RPM's about 4000 before the Alternator starts to charge around 13.3v (Which I think should be more than that). Also if i turn on any accessories it will read a lower voltage.Before I rev motor it is about 11.8v. I replace alternator and have new Optima Red top battery. I checked all ground locations they are all tight. Also these readings are from my DVM, not just from the display in car. I did research on internet and maybe starter connections, but I check all connections and they are tight. Any ideas would be helpfull,
Thank you in advance,
Jimmy
Old Jun 26, 2014 | 07:54 AM
dadaroo's Avatar
dadaroo
Are you saying you replaced the alternator and battery with no change in the problem? Or, did you put them in as part of your work and now you have the problem?
Old Jun 26, 2014 | 08:07 AM
ssrallyred's Avatar
ssrallyred
You should be seeing around 14v at idle, a little less with the lights on at idle. Original alternator ?
Old Jun 26, 2014 | 11:33 PM
xtremeironworks
Default You are correct
I first posted in General, then thought i should post issue in technical. I tried to delete from general, but could not. Sorry for the confusion.
Jimmy
Old Jun 26, 2014 | 11:38 PM
xtremeironworks
Default this is what the battery reads
12.42Vdc when car is off. But when car is running I read 11.99Vdc. When i rev car up to 4500 rpm's the battery reads about 13.2Vdc. I had the battery checked by Autozone and they said it was good. This battery was in car before I did all my upgrades and it was good then. I did buy a new alternator and had them check the new alternator again.
Jimmy
To c5 alternator charging issues
