Replacing brake rotors
I will be replacing my brake rotors soon and i want to go with slotted and cross drill because I like the look. I have seen photos on this forum of brake rotors that still have a "polished" look after many years of use!
It seems that rotors that are several years old would normally have groves in the rotors that would destroy the "polished" look. Is there a way to avoid the groves?
To maintain this polished look on the rest of the rotor do you have to polish the rust off on a regular basis or coat the rotors with high temp clear?
Many rotors are zinc coated, but I suspect that the zinc coating will not retain the look I want after several years of use.
I am considering Hawk shoes, but is suspect that the type of shoe may be related to the groves.
I am also aware of Cryo treatment. Does this help to retain the polished look I am after?
Good looking, lasting appearance, and extremely good value.
http://forums.corvetteforum.com/c5-g...ed-rotors.html
DeclaRotors and Hawk pads sounds like an excellent performance choice, but I do not race. I do like the idea of a brake upgrade for safety.
I am concerned about Brakemotives's six month warranty, Baer is three years, but over double the cost. While I really like the look of cross drilled rotors, I do understand they are more likely to crack.
if it does, you want what's called a high carbon rotor. iron isn't made all the same by a long shot and many of the china rotors sold today under the ac delco, raybestos ect labels are low carbon, that means they stay kind of grey and won't even have that gleam a high carbon rotor will. i have the cheap ac delco durastop rotors on my z06 and used them just because i view rotors as throw aways. they don't gleam no matter how hard you brake. low carbon iron. truth be told, next time i'm buying high carbon centrics
centric has a high carbon line that's around 70 dollars a rotor or you can get the same rotor slotted and drilled only it's sold under their stoptech label, the baer rotors that are 200 and something a pair are also high carbon
you also don't want ceramic pads or race pads as both will eat on the rotors. i second that recommendation on the hawk hps, that pad offers good street performance and is soft enough not to grove rotors and offer a polishing effect
there are multiple ways to prevent rust but the 3 best ones are zinc plating, ceramic plating and hard anodize
the cheapest route is to use bbq paint and bake it on in your oven and or do enough hard stops to get your rotors up to 500deg or so
It looks like I can find some high carbon ones for even less:
http://www.ebay.com/itm/FRONT-REAR-R...45718b&vxp=mtr
One year warranty, instead of three and I wonder is the quality would compair to the Baer?
Anyone familiar with these?
* what is "high carbon?
there are no guidelines, anyone can label anything these days
tire rack has the centric 125 series high carbon rotors which i know are a quality product and able to give you that look you're after, or, if you want slotted that same rotor is called the stoptech sport slotted rotor
the centric 125s aren't bad, $250 for a set of 4, that jumps to 350 a set for the stoptech slotted. summit racing also had good deals on the baers but they are even more
pads i agree, OEM would be good, HPS would be good. a decent semi metallic would be good, just no ceramic and no HP+ or stronger autocross pads
Last January I installed a new set of Decelarotors, but this time switched to Carbotech pads - MUCH BETTER! Quieter and smoother stops ever since.
except for the Hawk pads. Take a look at a rotor friendly pad like the Carbotech 1521.Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
when carbotech does this and if the numbers look good maybe i'll try a set, i just don't see the value in the "premium pricing" at carbotech when hawk offers better customer interaction
if you know the guys at carbotech you may ask them this sometime
