check engine light came on
Old Jun 29, 2014 | 12:59 PM
20roadking11's Avatar
20roadking11
Default check engine light came on
how do I determine what my problem is? All I found in owner's manual was to push reset. I did,light still on.
Wayne
Old Jun 29, 2014 | 02:18 PM
Pull the codes from the Driver's Information Center (DIC). Do a search on how to do that and then post up the codes that display on the screen. One thing that will cause the check engine light to come on is if you don't have the gas cap on tight or if it is defective. Might just want to check that.
Old Jun 29, 2014 | 02:20 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Old Jun 29, 2014 | 03:11 PM
jph1972's Avatar
jph1972
Need more details. what happened when the light came on? Were you driving or just starting the car.
Old Jun 29, 2014 | 04:27 PM
20roadking11
I had been driving it for about 10 minutes & the light came on. I did not notice any difference in the cars performance or anything not working as it should.
Old Jun 29, 2014 | 04:31 PM
20roadking11
Thank you Mr.Bill
Old Jun 29, 2014 | 09:42 PM
jph1972's Avatar
jph1972
Yeah pull the codes... I recommend video recording the codes, the DIC kind of goes through them quick, this way you can pause the recording and do your research on each code.
Old Jun 29, 2014 | 09:49 PM
Mr.Bill's Avatar
Mr.Bill
Wow, It really isn't that hard or complicated to read the codes...
Paper and something to write with will work.
Old Jun 29, 2014 | 11:25 PM
jph1972's Avatar
jph1972
You got your way I have mine.... oh well.
Old Jun 30, 2014 | 08:31 AM
dadaroo's Avatar
dadaroo
Maybe this will be better than a video camera or speed reading:
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M.
To check engine light came on
