Need lowering help
Old Jul 1, 2014 | 09:25 PM
Robbiejaegle's Avatar
Robbiejaegle
Default Need lowering help
So I'm trying to lower my c5 and my one of my front bolts are frozen/stripped. Iv been spraying it with pb blaster and tomarow I'm going to try and turn it with vice grips again but if that don't work can I lower the a arm and hammer the bolt to push it out the bottom iv been told by a few people on another forum to do that. Also can I ever get a new bolt and what ever it screws into back in there if I hammer out the old?
Old Jul 1, 2014 | 09:46 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I sure wouldn't hammer it out, That will screw up the spring, Let it set overnight with a lot of allfree on it and be sure to take the weight of the car off it. Taking a hammer to it is some kind of redneck **** there...lol
Old Jul 1, 2014 | 11:00 PM
Robbiejaegle
I wasent sure if it was a good idea or not I was told by some other people that's what they had to do. I'm really stuck on what to do I need to get it done soon beacuse it's sitting in my dad's business taking up space and I don't want to have to align it with out it being lowered beacuse I could not get the bolt to turn
Old Jul 2, 2014 | 02:01 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
So hammering it out is not a good idea. The spring is a composite material and you will just hammer out the boss that the bolt screws into. As noted try soaking it in a penatrating oil and then using a socket with an extended breaker bar. Applying some heat to the bolt, stay away from heating the spring, may help. Also you cannot buy the bolts separate from GM, only comes with the entire spring. You can buy aftermarket bolts made for lowering however. In an extreme case you can weld a larger nut to the bolt to use a larger socket to gain some leverage in getting it out. And as noted also make sure you take the tension off the spring when attempting to remove the bolt. Good luck.
Old Jul 2, 2014 | 08:07 AM
ZF Six's Avatar
ZF Six
I had an issue getting my bolts out of the front (replaced with longer bolts).
I ended up putting the bolt in a vice (while attached to the spring) and then turning the spring itself. It went slow but it came out and I was able to get the new bolt in. It had some resistance but didn't seem to damage the threads.
If you have a lift and the right tools, getting the front spring out is not very difficult.
Old Jul 2, 2014 | 05:52 PM
Robbiejaegle
I got the bolt to turn but it quickly snapped so I cut the bottom of the bolt. It sits pretty low but I lowered the back on stock bolts but it does not sit low at all. It hardly lowered. I put a 1/8th peice of rubber between the spring and a arm in the front also.
Old Jul 2, 2014 | 06:26 PM
Mr.Bill's Avatar
Mr.Bill
Wow, A C5 stock looks like a 4x4 and you installed longer bolts?
Old Jul 2, 2014 | 07:24 PM
chuckeb84's Avatar
chuckeb84
Old Jul 2, 2014 | 07:56 PM
DEnglish29's Avatar
DEnglish29
Had the same problem on the left side, let it soak a couple days with PB blaster, it broke loose. You'll have to use a quality wrench ( Mac, snap on or Matco) use a cheap wrench it's gonna strip the bolt head.
Old Jul 2, 2014 | 10:01 PM
Sam Handwich's Avatar
Sam Handwich
Default Frozen bolts
I have alternated heat and cold along with the PB Blaster in the past on stubborn stuff like this. I have a heat gun that goes up to 1150 degrees F. And you can get cans of compressed air to do a quick chill. Between that and the PB Blaster you should be able to get it loose.
To Need lowering help
