After removing the front calipers and caliper brackets, I was unable to remove either of the front rotors on my 2004. Car has 37,000 miles, and I am the 3rd owner. Don't believe it has ever had a brake job. I have encountered countersunk flat head screws on my Honda, but did not see any such screws holding these rotors. Tapped on the backside of rotor with block of wood and hammer, with no luck. Am I missing something? Do I dare spray some WD40 on the back side where the rotor mates with the hub? Thanks for any tips.
I run across this every day. Take a small sledge hammer and wack the hell out of them between the studs, not where the pads make contact. It'll pop right off after that.
Look closely at each stud, make sure the assembly lock washer has been removed. Also as mention rust can cause the rotor to stick, a heavy bronze or brass hammer will shock the rust.
I borrowed this from Member Dee Gee Note lock washer at the 1 o'clock position. A drop or two of rust blaster or an equivalent between the hub and the rotor will also help.
Next time, or if you want to put car back together try this. Slightly loosen the lug nuts on each side, then, in a safe spot where you can apply the brakes, put your car in gear and apply the brakes several times, in forward and reverse. Your rotors wll then be broken loose.
I've run into this dozens of times. I've discovered that the best and easiest way to remove stuck on rotors is with an air impact hammer. Using the round chisel, you just hit it around the center hub and the studs. The rotor usually falls off by itself.
Thanks. Yes, those two assembly washers fell right off when I grabbed them, so I know those things are not the problem
The factory uses thin sheet metal clips to retain the rotor to the hub during the trip down the assembly line. If they are still in place take them off. Otherwise it is just rust between the hub and rotor. Some penetrating oil will take care of that. I use a product called Kroil. Brake cleaner will remove any that gets where you don't want it.
Alternatively a 3lb hammer used as the previous posters suggest will break them free.
Thanks. I will try some penetrating oil such as Liquid Wrench or Kriol.
