Reverse lights not working
Old Jul 13, 2014 | 03:44 PM
Glenn25's Avatar
Glenn25
Default Reverse lights not working
Ok, noticed last night that my reverse lights are not working, changed the bulbs, didn't help, changed the relay under the hood, didn't help what are the chances it's the switch on the transmission(6 speed) and the car is a 2000 coupe. Any help would be appreciated. Thanks in advance.
Old Jul 13, 2014 | 04:07 PM
chuckeb84's Avatar
chuckeb84
These guys talk about that
http://forums.corvetteforum.com/c5-g...dont-work.html
Old Jul 13, 2014 | 05:14 PM
65GGvert's Avatar
65GGvert
You could have saved yourself a lot of trouble. Changing the bulbs takes longer than pushing your fob to see if your approach lights flash. If so, the bulbs are good. If they flash, your two choices are fuse 21 in the passenger floorboard, or the reverse light on the transmission, or both. If the switch shorted to ground, it will blow the fuse. If it opens, the lights won't work, but the fuse will be good. Read the link provided in the post above for pictures of where it's located. The switches are a common failure item.
To Reverse lights not working
