HB Replacement....Time Frame Needed ?
Old Jul 17, 2014 | 09:08 PM
SG Lou's Avatar
SG Lou
Default HB Replacement....Time Frame Needed ?
I'm not getting any bites in the Tech Section so I thought I'd post it here :
Guys,
I have noticed a oh so slight wobble so I think it's time to replace the harmonic balancer before bad stuff starts to happen.
I got the skills, that's not an issue. I got the tools, well most of them,and the Factory Service Manuals.
I have access to a lift at work and I also have 12 hrs in which to do it in...
( shhhhhhh, don't tell'em I'm doing it on Company time )
Anyway, I know I'm gonna need a HB puller and Installer and a 250# Torque Wrench. Barring any unforeseen problems can it be done in the allotted time frame ?
Am I forgetting anything ? Anything else I can do while it's apart such as Seals, Gaskets, inning the HB, etc, etc. ?
Oh, one more thing ? Suggestions on a Balancer ? Not looking for anything fancy like under driver and such.
Old Jul 18, 2014 | 11:07 AM
dadaroo's Avatar
dadaroo
You don't need a 250 ft-lb torque wrench and using one actually requires YOU to be able to pull that much which I can't do.
You can put an extension on a lower range torque wrench which increases the effective torque while reducing what you actually have to exert.
I have made two different sizes for my own use (cost about $12 each) but does require welding which I did myself. Or, they can be purchased. If you are interested in what I did just PM me with your phone number and we can discuss.
It just requires a little simple math to determine what reduced torque you need to pull.
PS: If your 250 ft-lb torque wrench is very long then you may be fine. I did not want to purchase another wrench to maintain calibration on.
Old Jul 18, 2014 | 11:38 AM
eddiebroadway's Avatar
eddiebroadway
7th Gear
The LS style engine takes a three finger puller and a special installer. The traditional installer kits will not get it done, not sure about the new ones on the tool trucks. I bought my installer online, works great. The steering rack and a bunch of other stuff is in the way, but 12 hours should be enough. You can put a new seal in the timing cover but if you remove the cover you need a line up device, or leave it loose while you install the balancer then guess at the alignment, it does not have dowel pins. While you are right there it might be time for a waterpump and hoses? Hope this helps!
Old Jul 18, 2014 | 02:43 PM
Curt B's Avatar
Curt B
I just went thru this and will add the following:
1. Don't forget a crank holding tool. I made a simple one that worked like a charm for both removal and install.
2. While you're there pop the seals out of all the tensioner/idler pulleys and clean and re pack them.
3. My wheel lock worked beauty for resting on the crank snout to support the puller.
4.My balancer had a nasty groove worn in it where the seal rides. Prolly a good idea to have a new seal in hand depending what you find.
Old Jul 18, 2014 | 03:38 PM
Lee DeRaud's Avatar
Lee DeRaud
You lost me with that one, assuming by "extension" you mean a pipe or something to lengthen the handle.
Yes, it will reduce the force needed at the handle to exert a given amount of torque at the socket, but it won't increase the torque range the wrench can read. Once it maxes out, it just becomes an expensive breaker bar.
To HB Replacement....Time Frame Needed ?
