Supercharger & Valve Spring Question:
What's up everybody. I recently swapped out my valve springs in my 2002 Z with the PAC 1218x (beehive) springs. I plan on adding A&A's supercharger kit as well. My question is Will these springs be ok to run with a supercharger? Thanks for your input.
PAC 1218's are pretty stout! At least that was my experience. Who knows what the future holds tomorrow.
Nice! Thanks for your response rick. I knew they were stout, but wondered if they would hold up with FI. What kind of supercharger are you running and how much boost? Also, will the stock clutch hold up? And if not, what kind of clutch do you have?
Received 1,764 Likes
You will do good with them. But if me I would have them checked out to test them that all are good are about the same. Dont want a bad are weak spring. Robert
Received 1,261 Likes
I am running pac 1518s over 700rwhp and no issues so far... my stock clutch held fine at 420rwhp and when I did the blower the clutch completely let go at about 8psi which I would guess was about 600hp or so... if you do a blower just go ahead and put a good twin disc in, you will need it
So. Would you say go ahead and get a twin disc? Or could I run the stock clutch for a while?
I know eventually I would need to upgrade. But is it absolutely necessary for the time being? Thanks for your response Neutron.
