grinding down rear spindle??
Old Jul 20, 2014 | 06:12 PM
slpws6's Avatar
slpws6
Default grinding down rear spindle??
Can I grind down the very top of the rear spindle where the 2 little humps are? There rubbing on my 17x11 zr1 wheels. Thanks
Old Jul 20, 2014 | 06:46 PM
NukeC5's Avatar
NukeC5
You can a little. I did to get my 16" drag set to fit. But be aware, they are caps to the ball joint underneath. If you go through it will expose the ball joint and squeeze grease out. If you look closely, the side of the cap towards the outside of the wheel well is higher than the inside. You will need to focus on that part. Just do a little at a time until there's no rub.
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would buy wheels that fit before I would backyard fix my Vette.
That is just me.
Old Jul 20, 2014 | 09:19 PM
slpws6's Avatar
slpws6
Thanks nukec5. Ill disregard mr.bill as it doesnt help me.
Old Jul 20, 2014 | 09:26 PM
striper's Avatar
striper
What about a slight spacer? While I'm not a fan of wheel spacers, a thin one could be a solution without grinding on a suspension part. I'd be very hesitant about doing that.
Old Jul 20, 2014 | 09:39 PM
f6john's Avatar
f6john
And then there are LG drag spindles.....
Old Jul 20, 2014 | 10:00 PM
slpws6's Avatar
slpws6
I just really dont understand why these wheels dont fit. Do guys that are running these run different spindles?
To grinding down rear spindle??
