Trans service
Old Jul 22, 2014 | 11:02 PM
dcw70's Avatar
dcw70
Default Trans service
Newbie C5 owner. Vette has 107K on it changeing engine oil on it this weekend and thinking of transmission fluid too. Should I drop pan and do filter and gasket or just drain and refill? No service history, no trans issues, just want take proper care of it,love the car Thanks in advance!
Old Jul 23, 2014 | 08:44 AM
dadaroo's Avatar
dadaroo
I recommend to change and replace the filter. I do not recommend you flush the system.
What I do in automatics is after driving for a while is to later drain and refill since the original drain did not get all the fluid out from the lines, cooler, and converter. Just do it until what you drain out looks the same color and what you are putting in. Normally once is enough unless the original fluid you drained was badly burned.
Some people do the drain and refill/filter and then disconnect/redirect the return line into a bucket and run the car on a lift or jackstands. They let some dump and then put more fluid in. They do this until what comes out looks the some as what goes in. It works, I just prefer my approach.
Old Jul 23, 2014 | 11:51 AM
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
I'm about to do this on my coupe. Any "GOTCHAS" I should watch for? Doing it on jackstands in the driveway.
Old Jul 23, 2014 | 02:43 PM
T5Mika's Avatar
T5Mika
- Getting the filter O-ring out can be a little hard. I used a sliding hammer...
- You need to fill it while engine running, and the exhaust will be hot, use some sort of heat shield.
- The tranny needs to be in a particular temp range and it you dilly-dally, it will get too hot and you end up under filling the fluid (since it expands when hot).
Old Jul 23, 2014 | 05:16 PM
Curt B's Avatar
Curt B
Originally Posted by T5Mika
- - You need to fill it while engine running, and the exhaust will be hot, use some sort of heat shield.
I thought the elbow I made for my suction gun was pretty clever so that I could fill it without burning the fill hose on the exhaust pipe. Then I burnt my hand installing the fill plug.
I would suggesting draining/filling the diff while you're there.
Old Jul 23, 2014 | 05:28 PM
I too would recommend draining the fluid and changing the filter while you are in there. with 100+K miles on the car, the fluid is probably pretty dirty.
To Trans service
