Horn doesn't always work
Old Jul 24, 2014 | 08:09 PM
VETTEC599's Avatar
VETTEC599
Default Horn doesn't always work
The horn on my FRC doesn't always work - especially when the car is very hot inside from sitting outside under the sun and it is very hot outside. Very annoying. Any suggestions as to a solution?
Old Jul 25, 2014 | 04:17 AM
C5Z06CE's Avatar
C5Z06CE
Check your clips that hook the wires to the horn. Mine were loose and just needed to be pushed in a bit.
Old Jul 25, 2014 | 07:34 AM
runner140*'s Avatar
runner140*
You have to take a closer look (wire/broken part)....not a typical C5 problem, ie. the list.
Old Jul 25, 2014 | 07:47 AM
dadaroo's Avatar
dadaroo
Could be almost anything but probably related to the membrane in the steering wheel. The next time this happens can you use the key FOB and get the horn to work? This would help in diagnostics.
To Horn doesn't always work
