cupped tires?
Old Jul 26, 2014 | 02:02 PM
t tom's Avatar
t tom
Default cupped tires?
have 2003 vert with 12k on it. Has original runflats on it! Was cleaning out front of radiator and noticed front tires are really cupped badly!! Will be putting new Hankooks on soon, but what would cause the originals to be this bad? Car handles and drives fine, doesn't pull one way or another! They are only cupped on inside edge. Is this a common thing with these runflats? Don't want to ruin a new set of tires if something is amiss! Thanks, Tom
Old Jul 26, 2014 | 02:13 PM
jrose7004's Avatar
jrose7004
Your car needs an alignment. Have it checked because it'll do that on whatever tires you install.
Old Jul 26, 2014 | 04:11 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Wear only on the inside edge is usually alignment.
Cupping is usually wheel balance, worn/loose parts, or shocks.
Old Jul 26, 2014 | 05:44 PM
Lee DeRaud's Avatar
Lee DeRaud
Sounds like OP has a bit of both.
Since it's unlikely to have fallen out of alignment in 12K miles, maybe it was lowered and that increased the camber?
(Or decreased...I can never remember which way it's measured. Leaning in at the top is what I meant.)
Old Jul 26, 2014 | 05:54 PM
t tom's Avatar
t tom
hasn't been lowered, have read on another forum that these cars have a negative camber adj. and that the run flats have a large square shoulder and hard sidewall which will cause inside edge cupping even on low milage vehicles! so time for run flats to go! like I said car drives straight , no pull, or vibration, worn parts at 12k just doesn't seem feesible, thanks
Old Jul 26, 2014 | 06:21 PM
Phanni's Avatar
Phanni
It is usually a good idea to get a full alignment (front and rear) when replacing tires as expensive as we run. I would find the best alignment shop in your area (the technology has changed a lot over the years), and have them tell you what changes were made and why.
Old Jul 26, 2014 | 07:01 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
12k miles is along times without checking the alignment. Also don't assume it left the factory correct. I've redone many new cars right off the showroom. Especially the grand sports. They had issues with inner front tire wear due to excessive negative camber. The car is 11 years old. The spring do lose some tension over time.
Old Jul 27, 2014 | 09:35 AM
t tom's Avatar
t tom
very good points! Will have alignment done when new hankooks go on! appreciate responses, Tom
To cupped tires?
