Help: Outside Air Temp Sensor Wire Broken
Old Jul 26, 2014 | 02:10 PM
Narco944's Avatar
Narco944
My air-conditioner has been showing 69° for a a while so I figure I needed to replace the sensor. When I got everything out I noticed a green wire going into the harness plug had come out. What do I need to do? I tried pushing it back and but it just slides right back out. I have zero experience soldering anything and I have a limited amount of wire up there to work with so there is not much slack.
Old Jul 26, 2014 | 04:20 PM
bjones7131's Avatar
bjones7131
Will bigger wire fit n female connector, if so insert and twist wires together. Wonder why wire came loose originally.
Old Jul 26, 2014 | 05:24 PM
Narco944's Avatar
Narco944
8vette7...you were close. Daddyrama also texted me the same advice. Oreilly's had an oem harness but Autozone and Advance didnt even carry it. The generic plugs were all a little too big to fit. It was $32 bucks. Good news is the sensor I thought was bad is probably still good so I'll get back about $15 from that.
To Help: Outside Air Temp Sensor Wire Broken
