After getting the engine rebuilt, I figured I would take the opportunity and install a short-throw shifter as it's something I've been wanting to do for a while.
There's Hurst, B&M, MGW, etc. Essentially, they all seem to do the same thing... If they perform differently, I am not sure what the different brands offer.
I'd like to retain the factory shift ****, so hopefully that narrows down my choices.
With that said, what does the C5 crew recommend? Is there a specific brand that is the short throw shifter to go for?
Thanks much!
I like the C6 shifter.
It's significantly shorter than the C5 and the round **** is like a ball joint extension of your hand.
I actually mounted the **** 1 inch higher and drilled a 1/8" hole in the stalk for a short coarse screw to hold it in place.
I have a padded console and the extra inch made it perfect for me.
I used a hurst short shifter, its like a cue ball on a stick, I didn't much like it, that's the only info I can offer at this time lol.
im sorry for the off topic question , but im really interested to know what rebuild kit you went with , and what your total costs were to have it done?
Feel free to pm me if you don't want to say in main. thanks
Stock C5 stinks
Hurst rattled and buzzed all the time
C6 was ok and an improvement. There is a vendor that sells this with a shortened threaded rod.
MGW is the best of the lot. I really like it. No rattles. Nice and tight.
I have the Mgw and I love it. It's a huge improvement over the stock unit. I went from stock to the MGW though so no comparison to an of the other available units.
I just installed a used C6 shifter. I reused my shifter box. I also did the Anti Venom mod. There is a noticeable improvement. It is not as radical as the MGW but I am satisfied with it. I would suggest that you ask some of yout Corvette friends to try their different shifters. The MGW has gotten a lot of good reviews.
I have the MGW. It is a nice short throw with very precise gates.
The effort and notchiness is much more than stock. I didn't like that. I did the anti-venom mod with one washer and it is much better. I like it a lot now.
Sounds like MGW is the winner. Thanks to the B&M folks for the feedback. I definitely want to avoid any further noise - buzzing and rattling is not appealing.
I'd be curious to see what the MGW feels like before and after the anti-venom mod.
Threaded for C5 ****. You can usually get aftermarket ***** in a variety of threading... I'm sure you'd be able to find whatever you liked in the 9/16-18 thread.
I use the MGW race **** with mine and love it (it's threaded).
Originally Posted by jgump
Hurst rattled and buzzed all the time.
Originally Posted by hdrider1
I had the Hurst shifter in a C5 and can verify that it rattled and buzzed.
I have the Hurst. Mine does not rattle, but does buzz at WOT above 5000 rpm.
I got rid of the iconic Hurst ball and replaced it with the long (4") Hardbar delrin **** which is much easier to grip. It also gives much better leverage, enough that I decided not to do the anti-venom mod.
