[Z06] Breather
Old Jul 27, 2014 | 11:53 AM
wmjosjr's Avatar
wmjosjr
Default Breather
I have a question. 2004 Z-06 C-5 LS-6, I have a, what they refer to as a Valve cover oil cap breather. It basically replaces the oil filler cap with a breather element. Wen I did that I noticed it was hitting, and leaving a mark on the interior fireproofing hood material. is that normal, or do I need to remove the plastic oil fill tube, and if so how does it get removed, twist off, or preyed off? The breather element is a screw in.
Thanks,
Old Jul 28, 2014 | 04:03 PM
tlove32's Avatar
tlove32
That's normal as it sits a lot higher than the oil cap. I took a razor and cut away the material so it wouldn't come in contact with the breather element.
Old Jul 28, 2014 | 08:09 PM
Z06-FIX's Avatar
Z06-FIX
Why ? What is it needed for ?
Old Jul 29, 2014 | 02:36 PM
tlove32's Avatar
tlove32
I use it to vent the crankcase for my forced induction setup
Old Jul 29, 2014 | 04:13 PM
Jims Z06's Avatar
Jims Z06
Does your breather have a check valve in it, or just a straight breather?
Old Jul 31, 2014 | 02:39 PM
tlove32's Avatar
tlove32
It has a check valve
Old Aug 2, 2014 | 10:11 PM
wmjosjr's Avatar
wmjosjr
Thanks for your reply. My mods are cam and heads. does it make a difference, with or without a check valve, I have a straight up breather for my application?
Thank you
To Breather
