[Z06] My DIY Catch Can
Home Depot Racing (Husky) 3/8" NPT air compressor filter - $24
http://www.homedepot.com/p/Husky-3-8...03AV/100040942
Strip of aluminum - $ I don't know, already had it lying around
3/8" Fuel hose, a couple brass fittings, bolts/washers - ~$10
Misc tools, you'll need something to drill and tap the can so you can attach a bracket to it. I used M10 x 1.50 since there was enough space for this size of bolt and that's the bolt/thread you need to attach the other end of the bracket to the head.
The can that I got at Home Depot didn't look exactly like the one in the link I posted. What they had in the store was very similar, but had a few slight differences and there was a removable top section, which I decided to use to mount to the bracket.
I am going to pull the bracket off again here soon and paint it black (valve cover crinkle black paint) and round off the edges a bit etc.
Pretty happy with how it came out considering how much I've put into it. The valve at the bottom of the can part does appear to seal in both positive pressure and vacuum, but I JB welded it shut anyways, it's easy enough to remove the collection can in its entirety anyways.
Just thought I'd share. I didn't find a whole lot of DIY type threads for catch cans on this site when I was searching earlier.
No ..i usually dont throw any parts away.. so I still have that valve on my shelf , now I have to put that thing back on there some how theres not that much room left
